Ranger Spare (donut vs full size)
backporch
9
NJ
Ranger Off Road
245 75R16
My 99 Ranger has stock 245 75R16. I have a spare that is 255 70R16. A little wider and not quite as tall. I got it with a parts Explorer. It was in the back so I don't know what truck it was part of, but I see the impressions of the chassis on the sidewall where the spare tire is stowed.
I dropped my spare on the ranger and was surprised to find a donut, speed restricted, 15" steel wheel. Is this the standard equipment on a Ranger. What are the side effects of driving for any distance with that mounted? Is it possible that some Rangers might have a steel wheel spare that is 245 75R16? Thinking of checking junk yards next time I am around. I guess I also wonder if that tire would fit under the bed.
Thanks
Most vehicle lines get a single spare tire/wheel for the whole run. They pick something that is either the same as the smallest stock size, or a "close enough" middle ground kinda deal that will work well with all stock sizes, and a cheap ugly rim. The idea is that the spare is supposed to be a temporary thing, not a full capability tire and will be replaced by a new or repaired road wheel soon.
I wouldn't be worried about damage, but you may want to run it on the front only. It could put extra stress on the spiders in the rear. And obviously no 4x4 while its on.
97ranger xlt
11
Mass.
my 02 has the same size as yours 245 75 16's . the stock spare that is still underneath is a steelie that is a 15 i believe - they call it in the spec sheet "Limited Service Mini Spare Tyre" . i would be interested to hear if your 16 inch spare fits under the bed. for whatever it's worth i would not be driving too hard anywhere on my spare as it is over 16 years old!
Ha, at least you carry yours with you. My spare sits out behind the garage next to my spare tire mount.
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
My 04 Ranger had 245/75 16's and a 15" spare, my 11 has 235/75 15's and a 16" spare that's about the same diameter. It makes sense to someone, I guess.
sgtsandman
Aircraft Fuel Tank Diver
12,633
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Thanks
My spare is a 16" Continental on a steel wheel. I guess it's whatever they get the best deal on. I have an aluminum 10 tear drop on order from a recycling yard to replace that wheel with a matching spare since my OEM tires are getting too dicey on wet roads. Since the spare is aluminum, I also ordered a tire cover to protect the spare. Once I figure out where the best place to locate a grommet for water drainage, I'll install one and hopefully keep the rim from getting too trashed.
Enough about me. For most Rangers, they have an open differential, so differences in tire size won't make a difference if there is a height mismatch outside of some handling issues depending on what axle it is on. If you have a limited slip, tire size mismatch is bad since it could burn up you clutches if driven too long. I imagine lockers will have problems too but generally, unless they are locked or you have an Auburn ECTEC, the locker isn't engaged on road and I wouldn't run locked if you have a mismatched spare off road.
