Relieving Fuel Pressure? 91 4.0L Ranger
srisitt
8
Washington
How do you release the fuel pressure on a 91 4.0L? In my chilton manual it says I need a special tool to release the valve at the engine block, but some things I read online say to disconnect the fuel pump relay via a connector underneath the fuse box. I looked inside the fuse box and found a 30A fuse labeled for the fuel relay, if I disconnect this will it relieve fuel pressure?
fastpakr
2,832
Roanoke, VA
Disconnecting that and cranking would certainly do it. You could also wrap a rag around the shrader valve on the fuel rail (looks like a tire valve stem) and press the valve in so any pressurized fuel soaks into the rag.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
I just yank the relay/fuse, fire it up, let it run till it stalls, then get to work.
srisitt
8
Washington
Interesting, is there an additional relay underneath the fuse box then or is it just the fuse on the 91? I heard there’s a green relay that snaps to a connecter under there
fastpakr
2,832
Roanoke, VA
I'm surprised the relay isn't visible from the top of the fuse/relay box.
srisitt
8
Washington
Yeah, in a video I saw it’s underneath, you have to remove the fuse box to get to it. But the fuel relay fuse is right in the box and labeled on the lid.
fastpakr
2,832
Roanoke, VA
That ought to work as well.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
Or if youre really feelin froggy you can trip/unplug the inertia switch.
fastpakr
2,832
Roanoke, VA
The inertia switch isn't really designed to be used more than once.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
Then why did they put a reset button on it?
Same reason they put "wet paint" signs on something that has just been painted. " To make people touch it"
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
Either is toilet paper. But there are those amongst us.
fastpakr
2,832
Roanoke, VA
snoranger
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
To get it away from an accident.
The purpose of the inertia switch is to kill the pump in case of an accident, in order to prevent fuel spillage and/or fire.
So, since they put a reset on it in order to drive it from an accident, doesnt it kind of defeat the purpose if fuel really was leaking?
