Rust and dried gas impossible to clean out of fuel bowl.
1984ranger28
5
Davison, Michigan
2.8l
Hi, today I finally got time to further take apart my 2100, I got everything else dissasembled and cleaned, except for the fuel bowl. Theres seems to be rust and dried gas in the bowl. Carb cleaner does nothing. Any suggestions? Thanks, Lucas.
Ranger850
Doesn't get Sarcasm . . .
4,687
Tallahassee Florida
Stock 2"
Stock
Gas. Try cleaning it with gasoline
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Soak it in vinegar. You need an acid not a solvent.
Yup, gasoline and/or vinegar.
Fresh gas will dissolve the old dried gas crust. Vinegar or coke may be needed to get the rust.
Bird76Mojo
1,265
IL
I like Brake Clean for most things these days.
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
Not all carb clean is created equal. I soaked a carb overnight with Gumout and scrubbed it with a brush to get it slightly less cruddy. When the Gumout ran out I got out the Cyclo, sprayed it down, blew it off with compressed air and it was clean.
1984ranger28
5
Davison, Michigan
2.8l
Soaked it in the vinegar for the past two nights. Got all the rust and dried gas disintegrated. But left a black petina in the fuel bowl.
Good. Black patina is the oxygen being replaced with something acidic.
Coke and most rust converters contain phosphoric acid. When you apply them to iron oxide (rust) the oxygen molecule is displaced by the phosphorous molecule and you get iron phosphate, which is not corrosive.
