Soft Brakes After Axle Shaft Replacement
Calypso Ranger
5
Springfield MO
31X10.50
I Have a 1992 Ranger with the 8.8 (rear drum brakes) and had a bent axle shaft. I put two brand new ones in and everything went smoothly but after I buttoned everything up and took it around the block, my brakes were VERY soft. The only thing I touched on the brakes was obviously the drum had to come off to gain access to the axles. I never opened up the system so I don't understand why it would need to be bleed. The parking brake barley does anything when engaged now as well. Is there a way to tighten up the rear drums? Maybe since one side was bent the drum was loose to compensate for it? Not very familiar with drum brakes. I highly doubt there is any problems with the front brake components because they are all less than 6 months old and everything was perfectly fine before the axle shafts were swapped in.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Try adjusting up the rear brakes...
Calypso Ranger
5
Springfield MO
31X10.50
I think that’s what it is i’ve been looking at diagrams and when i did it the little adjuster fell out. so i think i just need to adjust them
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
They should be self-adjusting. Adjusting the star wheel is quicker but just driving in reverse and forward a bunch of times does the same thing.
Calypso Ranger
5
Springfield MO
31X10.50
okay, i’ll probably try just adjust it and see it that helps any and go from there.
Dsetz
27
Montana
2.8 V6
Brake hard when you reverse while you are doing the back forth shimmy as alwaysfloored suggested. Do it until they feel solid.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Self adjusting brakes only work if everything is free and lubed. If the adjuster fell out... good chance something isn't free. Pop the drums off... get a good look at everything... clean and lube the adjusters and replace anything not right. Give them a proper adjustment and be good for awhile. Stabbing/Pumping the brakes while backing up will keep them properly adjusted and your pedal height where it should be.
An ounce of prevention....
