Solar-powered Dash Mount TPMS Kits by Torxe at CARiD
carid
Supporting Vendor
Cranbury, NJ
The tricky thing about tires is that they can lose pressure unequally. Of course, all of the modern vehicles nowadays are equipped with the stock tire pressure monitoring system, yet not all of them could accurately tell you which one out of 4 tires is low on air. Our solar powered 4-Tire Dash Mount TPMS Kits by Torxe are completely wireless, solar panel charging devices, which will provide you with the up-to-date information on how well your tires are inflated.
Transmission frenquency: 433.92MHz;
4 pieces internal sensors;
Sensor pressure range: 0-116psi(0~8bar);
Sensor working temperature: -40°C to +85°C;
Transmission power: less 10dBm;
Depending on your needs order easy to install 4-Tire Dash Mount TPMS Kit (TPMS-03) by Torxe.
Or go with the legendary (TPMS-04) Dash Mount TPMS Kit.
Make sure to get your tires inflated properly, find your vehicle's recommended tire pressure and maximum PSI listed on the sidewall on your door jam.
Be always ready to hit the road and eliminate the risk of sudden flat tire appearance with Torxe, browse through the complete selection of high-quality Torxe Automotive parts & accessories at CARiD.​
THandcock
Tampa
2.3L
That looks like a very cool product! More people should be buying these for older vehicles before they put on a new set of tires. Even most new cars with built-in TPMS systems rarely tell you which tire is low. I loved the solar power aspect.
No members online now.
