Solid Front Axle Swap Poll (Whatcha got?)
What solid front axle have you swapped in?
  • Total voters
    288
Josh40601
MTOTM Winner
12
San Diego
you're a mod! Get that shit done son!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Josh40601
MTOTM Winner
12
San Diego
im more interested in the 2 unimogs.....
1freaky1
Thornton
Currently underway installing my HP FW D44 & 9" w 4.88s. I do need to figure out what to do about the ABS tho. Any ideas?
Josh40601
MTOTM Winner
12
San Diego
no clue buddy. I just run without the ABS, but i know the newer trucks have to use it correct? Talk to Bobby Walker or Whalstrom1. They should be able to help
Bray D
2012 UA Ranger
8
Manito, IL
I bypassed the ABS module deal and removed it. My brake lines come from my master and run to my calipers.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
you could potentially modify the current knuckles/spindles to use the ttb abs stuff from a 96.
PlumCrazy
2014 Truck of The Year
168
Millersport, OH
Solid Axle Swap 4x4
I did the same thing. Removed module, pump, and all ABS related wiring. Ran one line straight from Master to driver font wheel and split it off there to run to the pass side front just like the the older RABS trucks.
glfredrick
44/60 -- waggy width in front, J-20 in the rear. 5:13 gears, ARB front, lincoln-locked rear.
Front axle is located about 8" forward in the frame w/relocated steering box and 1.5" .250 wall DOM drag link, crossover, and track bar w/1 ton TRE.
I'll get the latest round of pics uploaded. Quite a bit of progress since I snapped these. Truck is just about ready to roll. :icon_bounceblue:
atrudeau
07/2012 OTOTM Winner
Colorado, Denver
Here is my SAS trussed HPdana 30 with 4.88 gears... Open diff for now but soon to have an eaton elocker to match the rear and a hydro assit.
christ2b
jonquiere /QC/canada
v6 2.9L
D44 79 full width F 8.8 arb ans 4,88 gear on 36/14.5 tsl... enough for my old 2.9L
allout
87 Ranger Scab. Shortened frame and w/b to 114". Full width D44/9" from a 77 F150. 5.13 gears with a full spool rear and spartan front. 38.5" Boggers. Still have a little work left to do.
BroncoIIer
Oklahoma
4.0L OHV
Full width Dana 44 and 9 inch off '79 f150. Master Rebuild Kits, lockright in the rear, and 5.13's
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
Coil sprung HP D30 :)
And I believe it's the first 98+ coil sprung 2WD with a sas.
jmidd2011
okmulgee, ok
2.9
EB d44 is about 2 inches . wen u center it under the truck il be 1 inch and not noticable as long as you swap upper buckets.
