Solid Front Axle Swap Poll (Whatcha got?)
What solid front axle have you swapped in?
  • Total voters
    288
armyhooker
Narrowed 78 F-150 HP44
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
My 87 Scab. 79 D44, 9", 4.56's lock rite in the front, open rear. Extended radius arms with JJ's, EB coils with 6" lift 63" chevy/aa leaf bastard pack in the rear.
Txbronco2man
302
D 50 sas
Got a set of axles from a 1999 F-250, 3.73 gears TBC, with 8" lift springs, changing direction though, looking at a 3 link setup, :icon_welder: lotta fabing though, old pic just started to swap about a month ago
CalobDangerRanger85
FORD
1985 ranger on a 1979 f150 had to shorten frame 19 inches running dana 44 and 9 inch full width on 33s with a 351w zf5 didn't cut the fire wall or fenders and still have a.c.
Sent from my SM-G930P using Tapatalk
Kellis135
5
Port angeles,washington
5.8l carbuerated
Started as a b2 blown tranny and didn't run for a few hundred bucks. Got it running and driving, drove it for a bit and then cut the back half off and decided to put a ranger cab on it. First it got a Dana 30 leaf and an 8.8. Now it just got a 351w c6 and super duty 50 and 10.5, 3 link with foa coilovers and 38.5s. 6 years into it now.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I originally swapped a 79F150 D44 under my rig but after the 302 swap I couln't go out without breaking front shafts. The first of this year I swapped in a set of 60's. Still have a few things to tidey up but so I haven't gotten to wheel it yet.
Junk Collector
Truck of Month
4,789
Rapid City SD
I have a 78-79 HP Dana 44 under mine. It has been narrowed to early bronco width on the passenger side. I was breaking shafts quite often and ended up putting RCVs in about 6 years ago. Problem solved. If I built another trail rig it would have one tons and probably would be a tube chassis instead of a Ranger.
deathbypsi
06/2012 STOTM Winner
MTOTM Winner
79
Mich
2.3turbo
My 86 B2 sits on a 77 Bronco D44 with 4.56 gears,Aussie and RCV's with James Duff SAS kit using their 3.5" coils. Rear is a 77 Bronco HD 9" with 31 spline Superior shafts and a spool. 35" KM2
Bracket racer
Canada Military - Veteran
235
Socialist republic of Nova Scotia Canadastan
Ranger supercab
Crap load
35X12.5 (bald so I don't break parts)
Low range in Nova Scotia on YouTube!
Yay!!!
I can finally say I got a d60 and 10.5 stirling from a 03 F250 for the donkey!
Now the fabrication starts...
