SOLVED: Whiring/rattle sound from bellhousing
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Hey guys,
I have a wiring/rattle sound coming from the bell-housing (2.9 into a Mitsubishi trans). It is most notable at idle and I think it goes away when I drive (could be I just cant hear it). Pushing in the clutch doesn't change things, I can still hear it. Ideas? My first thought is loose flywheel. It couldn't be the input shaft bearing, right? That would only make noise with clutch engaged.
rusty ol ranger
Im a Jeep guy now.
7,274
Michigan
177 CID
My first bet would be a flywhee,
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
That's what I thought. Gotta pull the tranny anyhow to change a seal.
I used the old flywheel and bolts when I installed the engine. Shouldn't have. Didn't use locktight either
Bird76Mojo
1,264
IL
I'm guessing it's a broken pressure plate finger, or a broken clutch disc spring.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Maybe, but they were brand new when I put them in less than 10 miles ago. Still could be though for sure.
Bird76Mojo
1,264
IL
Yep, only one way to find out..
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
So I am pretty sure the sound has nothing to do with the flywheel. The other day I lost the plug that goes in the driver side exhaust manifold. It must have been loose ever since I installed the engine. When I lost it, s**t got loud quick. I used a 1/2 inch pipe plug to close up the hole. Not only did the nasty exhaust sound go away, so did my rattle whirring sound. I think the sound was actually coming from the Y-pipe. That plug must have been rattling in there and the sound was reverberating through the exhaust - making it sound like it was coming from the bell housing. Who woulda thunk it?
Kirby N.
March Truck of The Month
