spark plug suggestions
MAKG
19
California central coast
No, you have an uncontrolled variable and you don't know how the spark plugs affect that variable. It's not possible to separate it from a real effect.
Maybe your problem is that your coil pack is internally shorted, for instance.
Nailzs
salisbury, md. east of cheasapeake bay
4.0l
how do i find the problem then? no cel, runs good, good vacuum
bout all i got is a slightly rough idle.
its hard to diagnose something when all you have is a slightly rough idle and you have no idea what is wrong...
MAKG
19
How can the vacuum be steady if the idle isn't?
I'd try a cylinder balance test to see if any cylinder is dead.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
why you guys trying to argue this stuff with Mr. Gross? you guys should know better. He is a pretty smart guy when it comes to this stuff. put some 4.56's in it, solve your other variables and do your test again...............
bro2
columbus ohio
4.0 l
I was told in a engine diagnostic class to run the oem plug for best results.
bosh platinum spark plugs are the only spark plug that I have cause a running problem.
woodyedmiston
4
Texas
Spark Plug Suggestions
Eleven miles per gallon. I was getting 19 when I did some work on the motor and discovered that the spark plugs that I was supposed to have installed two years ago - were never installed. That means the truck had over 220K on the plugs that came in it from the factory. They didn't look pretty either. But even with a gap that could be measured with plywood it was getting better than 11mpg. I've really noticed a difference since I put in new plugs.
