- Sep 22, 2007
- 7,491
- Michigan
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 177 CID
- 2WD / 4WD
- 2WD
- My credo
- A legend to the old man, a hero to the child...
Ok...did alot of pokeing/prodding/etc today.....heres what i came up with...
I got 2.1 ohms when going from SPOUT connector to TFI plug. So that wire should be ok correct?
I got 0.00 ohms (not the infinite shorting ohms though) when i tested between the SPOUT plug and the ECM, key off. Normal or no?
Also, after unplugging the ECM to test the wire, the SPOUT started making a difference when i plug/unplug it.
With the engine running i got 6.0V at the spout connector with a battery voltage of 13.8.
Weird thing though, i checked fuel pressure, again. It was at 38 or so KOEO, but with KOER it would drop to like 32-34PSI, and when id hold the throttle open it would jump to 40, drop to 35, and slowly creep downward. I unplugged the vaccuum line it shot to 42psi.
I had a new regulator and installed it, but after that my pressure gauge quit working.
However, on a test drive it has gone now from LEAN symptoms, to full on, no mistake about it, flooding after the FPR change. Like, black clouds worthy of a 12Valve cummins. Shut it off for 10 minutes, fires up. Runs excellent.
I then went under the truck and poked O2 wires, as im getting the code 41 still. I had 12V on the green wire. .5 on the orange wire. Granted this was just testing with the key on.
So theirs the puzzle pieces, can anyone help arrange them?
