Strange Dash Noise
Guggenheim99
5
New Jersey
I have a strange dash noise. I haven't been able to record it. The only way I can describe it is as if there's a mouse inside the dash scratching real quickly. I obviously don't have a mouse in my truck. It's not consistent. It used to be only when the AC ran. Now it'll start doing it like 2 minutes after I start driving. Doesn't matter if I am accelerating or not. But it seems to only do it when I am cruising under like 50. After that, road noise starts and I can't tell. It can last for like 3 seconds or as long as 10 seconds. It's real annoying. And smacking the dash or climate control area doesn't make it go away, lol. Any ideas? I can try and video it if you want me to. Thanks.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
If you put the climate control all the way to off, does the sound disappear?
Gozi
27
Garland, TX
Ford Ranger XLT
P235/75R15
Mine started making that noise when I changed out my radio and bent one of the four metal clips putting it back together. Some plastic in your dash is rubbing against another piece and you hear a scratch. When you locate it try a product called Second Skin Overkill. There are also products that reduce scratching that are a rubber base spray, but haven't tried them yet.
Ranger850
Doesn't get Sarcasm . . .
4,687
Tallahassee Florida
Stock 2"
Stock
Are you sure you do t have a mouse in there?
ericbphoto
Overlander in development
16,548
Wellford, SC
3.0L
6"
Must be a relatively new truck if you're complaining of noises like that starting to occur. Wait til a dried oak leaf or business card falls down the defrost vent and lodges against the blower wheel. Or maybe get a Skittle rolling around in the vent ducts. But then you start to hear a loose tailgate, squeaky dry suspension bushings, lifters, steering whine, the loose heat shield around the catalytic converter...
Guggenheim99
5
New Jersey
No, it does it with climate control on or off. Heat and A/C. Used to do it only with A/C, now it does it with A/C off. Also found it does it with Heat the other day.
Yes I am sure, lol
It's a 2002. I've actually had a leaf get into the blower before, lol
Zapper
Yes i can afford this without "daddies money"
45
Buhl,ID
1986ish
ford ranger
2.294e+6 cubic millimeters
shot bushings?
235/75/r15
To send it or not to send it, that is the question.
or until it launches leaves at you
Guggenheim99
5
New Jersey
Digging up an old post. Turns out, it was bad front wheel bearings causing pieces in the dash to rattle. Replaced the wheel bearings because they were bad, and all dash noises went away
