Superlift front diff bracket bushing
Bird76Mojo
1,265
IL
Has anyone else here had their Superlift front differential bracket rubber bushing wear out? Mine is needing replaced, and I'm curious if anyone has sourced a replacement bushing from their local parts store. Getting anything from Superlift has always been a hassle when I tried. They constantly make excuses, say things aren't available separately, etc..
You notice the bushing is bad when you hit the brakes and you can hear a faint click or thud as the front diff rotates ever so slightly. The bushing seems to pinch off the rubber "flanges" on the ends of it. It would be nice if there was a more durable, longer lasting solution. I was just hoping that someone had already sourced one and had a part number for me.
This is the bracket I'm speaking of, and the bushing is seen to the right side of the photo:
GB :)
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Bird76Mojo
1,265
IL
It seems like the metal insert is a hair too short, which lets the rubber ends get chewed away. But if memory serves me, when I installed it, the metal insert couldn't have been any longer and still be inserted where it bolts in.
My main problem is it's my daily driver, so I can't afford for it to be down any length of time.
Thanks for the suggestion man.
GB :)
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
I agree, a common leaf spring bushing of some sort will likely fit that. They range in many widths from around 1.5" to 3", and diameters from 1" to like 2" or so. You just need the ID of your tube and the length of the inner sleeve. Or if your old sleeve is in reasonably good condition, reusing it should be fine as well.
Energy Suspension is another one that likely has something that will fit.
http://www.energysuspension.com/assets/files/energysuspension-catalog.pdf
Bird76Mojo
1,265
IL
I need to get a few days off so I can rip this thing apart for repair. I'm hoping to locate some poly bushings. Maybe they'll last a little longer.
I appreciate the suggestions. Thanks again guys.
GB :)
No members online now.
