Suspension Check
TexPace
After hours of reading, I would like someone to review my suspension idea and make sure I am not leaving anything out. Would the following combo be acceptable and would I be able to get it within acceptable alignment:
1987 Bronco II 4x4
Explorer coils with 1.5" - 2" coil spacer
Explorer leaf springs with Belltech 6400 / Autozone 6100 shackles
New shocks
How much lift would this provide? Would I need anything other than alignment bushings?
The main use out of this suspension would be to be slightly raised, street use, and occasional old logging trail roads.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,713
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
The Explorer coils are going to be stiffer, I doubt they'll give you any lift.
Skyjacker makes (2) different coil springs that will provide 1-1/2 to 2 inches of lift. The SKY132 is intended for 4-cylinder short bed trucks. The SKY132X is intended for super cab V6 trucks.
Daystar KF09101BK is a spacer that goes under the your stock coils for 2-inches of lift.
The longer shackles will give you 1-1/2 to 2 inches of lift. I don't recall, does the Bronco II have a rear factory lift block? If not, a cheap option would be to salvage one from a Ford Ranger 4x4.
Just don't exceed 2-inches of lift in the front, or you'll probably never get it aligned right.
TexPace
Jim Oaks, thank you for the information.
Bronco IIs do not have a rear factory lift block.
Tfish
Oklahoma
Bronco 2
I have a bronco 2 offroad use only and I am not worried about alignment . What I am asking is can I use the 1.5 lift/leveling coils and also use the 2 inch coil spacers for the front? And put blocks on the rear leaf springs? I have never messed with any ttb suspension I recently bought a b2 for offroading and have only ever ran chevy stuff so if this is a dumb question I am sorry.
Sweet-85'
Hastings, MN
Ford Bronco II
2.8 V6
2.8L 171CID
If it ain't broke, fix it 'till it is!
You can, yes, however, you'll want to get axle drop brackets. Your steering and camber, toe, etc will be way off and make it a pain to drive, off road or not.
