Switching from worn 35s to 32s
oranjvoodoodaddy
Hi folks,
I got a '94 4x4 on a 6in. Skyjacker kit. Anyone got pictures of the same setup with 32x11.5r15s? I'm thinking the tires will look small and wanna see if I can tolerate it.
Thanks for looking
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Take the tires that are on your truck now, and from the center of the hub measure out 16" and draw a circle in chalk around your current tire.
Then take a step back and look at it.
I know its not what you want but it gives you perspective.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Most 32 inch tires only stand 31.5 inches tall.
The gear are you running should also be considered.
oranjvoodoodaddy
Thanks, I gave it a go and it helped me see. The 35s already show a bunch of wheel well, they measure 33.25, so going down 2 inches from where it's at probably won't look worse. It seems like 6 inch lift is meant for 37 or 38 inch tires.
Junk Collector
Truck of Month
4,792
Rapid City SD
This is not exactly what you're after since mine is a different body style... but I did have a Skyjacker 6" lift and 32's when this picture was taken.
oranjvoodoodaddy
Looks okay to me. I'll post a pic when i get home for comparison. Thank you, Shran.
