Tachometer install
The 5.7 Ranger
Virginia
Ok, ive installed a gauge cluster with tach from an 02 4.0 explorer into my 97 2.3 ranger, the odometer reads off and everybody says its a ground wire that needs to be swapped. Is that true? If so who has the cluster wire diagram of a 2.3 with tach?
8,369
On the new cluster you will remove the ground wires for the number of cylinders in your engine
Originally Posted by rwenzing
96~2003 Ranger tachometer wiring for 4, 6 or 8 cylinders:
8-cylinder: "Selector" ground configuration:
  • pin 8 of the 10-pin: (NOT connected to anything)
  • pin 16 of the 16-pin: (wired to chassis ground)
6-cylinder: "Selector" ground configuration:
  • pin 8 of the 10-pin: (wired to chassis ground)
  • pin 16 of the 16-pin: (NOT connected to anything)
4-cylinder: There is no "Selector" ground
8,369
Good work (y)
Thanks for the update and the FIX
