The Chive
Rock Auto 5% Discount Code: 248EE46702D889 Expires: October 1, 2019
ericbphoto
Old Redneck just wingin' it.
638
Wellford, SC
6"
You're not supposed to think that far ahead.
Besides. They probably put it in there for better traction in the snow. It can stay all winter.
Ranger850
Well-known member
423
Tallahassee Florida
Stock 2"
Stock
right, get it in the truck first, then figure how to get it out later. Some chains or straps holding the rock up with the bucket would have been a help too. Who needs a rock:icon_hornsup: that big anyways?
Truckedup
New member
Marion NY
Picture one cubic yard of cured concrete ,3 x 3 x3 ft...it weighs 3500-4000 pounds...Does that type of stone weigh the same as concrete by the yard?
I have seen many grossly overload pu trucks on the road...The damage often occurs later on, like the owner bitching about bad axle bearings.
don4331
Active member
39
Calgary, AB
5.3
OK, I too was waiting for them to take out the box side/wondering how they get it out. (I would have chained it so I could lower it without dropping, removed it after.)
Ranger in question is Sport = 1,100lb rear springs, subtract the 1,500lb empty weight and payload was only 700lbs to begin with. Someone in video mentions, 1,700 lbs sounds about right - narrower than wheel wells which are 40", shorter than box which is 72" and just over box deep which is 16" puts it somewhere between around 15 ft^3. Using Truckedups, ~130lbs/ft^3 would be in that range.
So, while it overwhelmed the leaf springs of Sport, not near the capacity of the axle. When they finally got it out, springs probably recovered just fine.
Now, the tree in the back of the f100 - that hurt.
