The legendary 2.9 Free Floating Rockers
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Ok, so I'm sick with what I assume is the black plague, and I'm probably going to die, but I managed to get out of bed long enough today to check my current set of 89tm rockers:
Pass front 2.183"
Pass rear 2.040"
Driver front 2.036"
Driver rear 2.150"
All spring clips seem to have 0.100" between the rocker arm and roll pin
Bumping to get the brain juices back flowing. Originally I was going to subtract .025" from your measured dimensions, for the clearance needed. Whats this 0.100" rocker arm to roll pin? Does this affect the spacer length? struggling to picture it
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
WHAT
ARE THOSE REAL?!?!
I think I have a raging semi going.
Yup needed to take a break yesterday and banged them out, PM sent.
Not about the raging semi... Address to send these things.
Probably take me a couple days to get to the post office
Nez'sRanger
68
Pennsylvania
2.9L V6
I just finished installing a set of these on my truck. My dad made them on his lathe... I've yet to test it out on the freeway. I'll post updates and pics after I put some miles on it.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
DUDE
YES
NEZ I LOVE YOU
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Didn't want to break hiatus, but worthwhile update.
I screwed up the rocker shaft measurement, so despite Farmer's best efforts, the ones he made did not work, 100% on me.
Had a machine shop in Maine crank these out. Will update when my engine is back together (currently a bare block).
Paulos
210
North Carolina
1987 STX
So what size is the spacer/washer at the ends of the rocker shaft? Were shims necessary?
aclayton59
Near Rochester New York
B2
Building a 4.0 for a swap
Has anyone ever tried to contact Sven? He’s on Linked-in, works for FCA.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Have tried, no success.
aclayton59
B2
Well??? How about an update?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Dustin_89BII
23
Oregon
Hi folks, 2 years of pando later. Any luck on building a spacer kit or getting the results you were hoping for on your specific builds?
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
black plague??
No members online now.
