The ranger
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
Well I've got the gears, the filter and the new lug nuts. I'm waiting for the new shim kit to come in and the time to install everything. This week I'm probably going to make another run back to the old house to pick up a couple things I couldn't fit in my last load. Might have a little time on Friday to work on it.
Rock Auto 5% Discount Code: 57CD9601BD5AB4 Expires: July 1, 2019
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
Figured out the studder and back fire. ShittyCalifornia fuel. Added a second filter between the tank transfer valve and the high pressure pump. It's a oem filter off of a 92 f150.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
ericbphoto
Old Redneck just wingin' it.
112
Piedmont, SC
6"
Nice bag of mud!
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
Yeah, I cleaned both tanks when I replaced the sending units last year. So it's gotta be varnish. This time I put a clear filter just prior to the fuel rail along with a oem filter before the pump. So I will be able to see what's going on.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
I've started my attempt at setting up these used gears. Backlash is 10 thousandths. Any advice?
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
I think I've got them as vood as I'll get them. I'm gonna put the new bearings on tomorrow when I get home. The pinion and races are setting in the freezer still since I didn't have time to finish last week. I'm gonna install the new races and let everything get to the same temp. Then I'll re-check the pattern to make sure nothing changed. Then I'll move on to making sure the front end is set up correctly, but I have my doubts...
Bird76Mojo
Active member
135
Toledo, il.
2001 & 1987
4.0 - 5.0
4" Superlift
33"
Good enough
It's a pretty sure bet that something will "move" on you when changing the bearings.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
Yeah I agree. I haven't made time to work on it yet. We went to my wife's friend's so I could work on her jeep for her, this morning. So that messed up my whole day. Gonna start first thing in the morning.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
19
Squaw Valley, Ca
302
Finally got around to leveling up the front. I Also raised it an inch to improve the track arm clearance. Tomorrow I'm gonna trim the bottom of the coil buckets and the upper track arm bracket. Had a little mishap yesterday. Took the wife out into the back pasture to do doughnuts and the alternator cut a hole in the radiator hose. Luckily I had another that I was able to make fit, it fits better than the other and has more clearance than the other one had.
