Third Brake Light
Mike92STX
58
Zion,Illinois
I just got a 04 FX4 and the third brake light is leaking, after ordering a new gasket on ebay and getting the wrong one I decided to get a new after market brake light with LED lights. My question is the truck didn't have the bed light and the new comes with it has anyone wired a bed light on a truck that didn't have one? I'm guessing it can be wired to the dome light but I'm not sure.
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
Yes, it’s trival. I got one from a junkyard Mazda that had the cargo lights and installed LED bulbs. The wire from the dome light isn’t far away and you just have splice into it. I think the switched hot connection to the dome light goes through one of the mounting screws, so I just put a ring lug under the screw head - I may have a picture on my laptop I can get later.
Edit: https://www.therangerstation.com/forums/index.php?threads/adding-bed-lights-to-my-2004.179715/
Mike92STX
58
Zion,Illinois
That looks almost as easy as I thought except I didn't get the light from a junkyard so I couldn't get the extra wire. Might have to improvise a little. Thanks for the input and instructions.
Mike92STX
58
Zion,Illinois
Well, I got the new light today but it looks like I'm going to have to get another plug from a junk yard. It looks like the female end of the plug can be added to the 3rd spot on the plug but the problem is I don't have a extra plug might be able to get it from dealer? My other issue is I have the extended cab and I think I'm going to have to take the headliner out to run the wire because the liner is to close to the roof and it has some uneven spots that I can't get the wire through or over.
black_demon69
142
AZ
4.0l
Use a straightened wire coat hanger to fish the wire
Mike92STX
58
Zion,Illinois
Thanks Black_demon69 and 8thTon! I probably would have figured it out but you help made it a lot easier. I finally got it done yesterday, got another plug off a 150 at the junkyard and spliced it on to my truck with 1 wire going to the dome/interior light. The only thing that I don't think there is any way around is the cargo light comes on when I open the doors or unlock with the remote. it not a big deal, I just haven't noticed it on another truck. Thanks Again.
8thTon
--- Banned ---
806
Pennsylvania
That's how my old F250 worked, and while it's not ideal it seemed good enough given how simple it was to hook up.
