TLBNut
- Apr 22, 2019
- 0
- Clarksville, TN
- Ford, Ranger
Ok, I just bought a 1993 Ranger 2.3L 5 spd, it will not start. If you turn the key, power comes on but no start. I can start it if I turn key on and use a jumper wire from the positive post to the "S" terminal on the solenoid. I have replaced the following items, one at a time and no change. The Battery, clutch sensor switch, Battery cables, solenoid, Key lock cylinder and ignition switch. I am stumped. If I am not mistaken the only thing left in that system is the Ignition Control Module? That is a pricey part, so I want to be sure.
Thank you,
Thank you,
