Updating the Tech Library Transmission section - Suggestions Needed
Victorymike18
N/A
Hi,
I made a very functional transmission fluid pump the other day and wanted to share a picture. I had many of these components on hand, but can supply some closeup pictures of the fittings if that would help anyone.
Doing it this way kept my pump bottle from getting contaminated with ATF, so I can use it for other things.
My only improvement on this would be to add a shutoff valve towards the hose end at the transmission. The pump bottle has a pressure release which immediately stopped the flow of fluid, but the residual in the line dribbles out if you don't keep the end of the hose elevated. A valve on the end would solve this.
red2003xlt
TLH, FL
YouTube - FordTechMakuloco has got a series of videos regarding the 5R55 tranny.
Denisefwd93
74
South East PA
frame inspect / repair
Seems like with so many rusted & cracked frames, a more detailed write up, how to fabricate frame sections would be helpful
901wd#2
9
Vermont
Ford ranger
Gonna be pulling an 89 2.3 a4ld out to rebuild it.
Anyone have a simple controller beyond switches to make it a 6 speed by applying overdrive in 1st & 2nd
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
A minor contribution to "the cause"... I probably posted this in the wrong section:
