WHAT DID YOU DO TO YOUR RANGER TODAY?
fastpakr
Forum Moderator
244
Roanoke, VA
Like I said the other day - I've been taking notes.
It doesn't make sense right now but it's probably coming.
Some of it's easy - body lift to clear the valve covers/exhaust on the passenger side.
Cam synchronizer needs to be a hybrid of the stock unit and a 3.8 version to get me the right CPS setup and length, oil pump drive size, etc.
Harmonic balancer needs to be an Explorer unit rebalanced to 28 oz or a 28 oz balancer modified with the crank position tone ring.
Exhaust would be interesting for sure. No clear answers on what manifolds/headers fit.
Engine mounts need to be raised a bit for the oil pan to clear.
I could use my heads and try to retain the current headers, but there would be some modification required. Can definitely use my cam. Not sure on adapting the upper end components to the Explorer bits for throttle cables, EGR, PCV, cruise, etc.
Current computer should be okay, but I'd probably need to invest in an SCT to get it tuned spot on.
Lots of small hurdles. Too much for today...
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Uncle Gump
Well-known member
572
Plano IL
Lead, Follow or get out of my way
Yes... it will get pricey.
Good luck with which ever way you decide to go.
Forum Moderator
1,233
SW Iowa
That is a lot of hoops to jump thru...
40
Eustis Florida
3.0l Vulcan v6 with low miles...
stock since 1998
Sounds and acts like a old man....tries and fails at joking and being a smartass...
Well I got my old computer with outdated hardware running so I might be able to upload pictures guys, unlike this school laptop, going to wipe down my ranger today or clean out the interior....don't really know.
PetroleumJunkie412
2.9l Aficionado
1,287
Pittsburgh, PA
Depending on the year of your 5.0l, this is the only thing that makes sense for your ECU.
Yes, it's a steep up front cost. It absolutely saves money in the long run, though.
Plus, it comes pre-tuned.
fastpakr
Forum Moderator
244
Roanoke, VA
I'm not anti Megasquirt, but I'd rather not go down that road for now. The stock unit interacts with the GEM and gauges, plus it controls the transmission. In an earlier truck or one with a more standalone ECM or for a transmission swap it would be a lot more appealing.
The unit you linked would be perfect for a Mustang 5.0 conversion. Mine's running EEC-V out of an Explorer, so it's a separate problem set.
Forum Moderator
1,233
SW Iowa
I don't think it will work, he has a distributor-less 5.0 out of an Explorer, I think the same year as his truck.
masanders
22
Greenville, SC
2.5L
Don't get louder, improve your argument.
Spent the day building new battery cables to replace the temporary repair battery cables I put on there a couple years ago(ish). Probably costs more than pre-made cables, but I enjoy the process.
40
Eustis Florida
stock since 1998
Hey guys its done... I finally uploaded a newer picture of my truck, not the newest photo but it's when I just recently detailed my truck...
8thTon
Active member
177
Pennsylvania
40
Eustis Florida
stock since 1998
Hey, look at that - I wondered what color it was.....
Um is it bad that I used my color code as my username? Just sounded good at the time.......correct me if I'm wrong pacific green color code out of the other 5 green colors in 1998 is kinda rare....
alwaysFlOoReD
Forum Moderator
413
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
Not bad at all. I believe he was being tongue in cheek.
masanders
22
Greenville, SC
2.5L
Just finished installing my diy cables. Had to splice and solder, but everything turned out great! I’m getting more voltage from the alternator than I did with the old cable repair sleeve thingy.
Advice...get the pre-made cables and save yourself time, unless you just want to diy.
masanders
22
Greenville, SC
2.5L
