What engines will fit in my 1998 Mazda b2500
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
it turns over, but when it finally cranks it just sputters and dies. It wont charge the battery either. Ive checked the wires and replaced the alternator and the pcm, plus a fuel filter and pump
rusty ol ranger
2.9 Mafia-Don
7,484
Michigan
177 CID
Run a compression check.
I highly doubt this issue warrents total replacement.
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
i have already.
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
rusty ol ranger
2.9 Mafia-Don
7,484
Michigan
177 CID
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
no. ive got compression on all 4
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
I figure that feces actually dropped out of his tailpipe. That would be a good indicator ?;missingteeth;
rusty ol ranger
2.9 Mafia-Don
7,484
Michigan
177 CID
Ok then thats 1 thing down.
Open up the intake tube and snort some starting fluid in it while someone cranks it. See if it runs longer then it does normally.
If it does -Fuel issue.
If it dont- Ignition/timing issue.
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
we have done that. It did run longer, but not by much
rusty ol ranger
2.9 Mafia-Don
7,484
Michigan
177 CID
If you have compression and it runs, even for a few seconds on starting fluid the engine isn't toast. Not yet.
You have a fuel delivery problem by the sounds of it. A bigger engine won't make that better.
