jdunne03
- Mar 31, 2019
- 3
- MA
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
I hope I'm posting this correctly and in the right place.
So the problem started with a truck for sale....CHEAP ! I bought a 2007 Ranger in great shape BUT has a problem with the gear selector is stuck in 4th. Fiddled and diddled with shifter stub and reassembled, now it shifts in to all gears but 4th. Had to drop tranny to open it up for repair (or replace) and things start getting weird. Drained what should have been almost 3 qts of fluid and only about 4 oz of black goo comes out and the drain plug looks like black cotton candy. I figure the gears are all toast...NOPE, they look and move just fine. Being the proactive guy I am, I have my son pick up a rebuilt F87A AB (M50D-R1) from a guy on CL that wrecked his truck before he could install it. This came with a new clutch and good flywheel.
So I'm not a mechanic but am mechanically inclined, I watch a few You Tubes on R&R the Ranger trans and google for hints and tips..... All set, jack it up, start taking it apart and nothing looks similar. I figure it's just a newer model year. I have hard stainless fuel lines and a large cable loom bundle running the whole length of the trans on the top drivers side. The electrical loom is connected to the trans with push loks in 5 places, the connectors for sensors, O2, etc. are also mounted to brackets that have to come off first, as well as the fuel lines. I get all the bottom bolts out and I'm having a heck of a time reaching the top bolts, there is NO ROOM above this trany as it's about an inch below the soft heat shield/sound deadening mounted beneath and there is a 1 1/2" cable loom routed with a PVC or water hose right on top of the trans bell-housing running side to side. The only way to get the last bolt from top drivers side is 3 extensions for a total of 40" and feed it down the top with my left hand and use my right hand to reach around the trans and guide the socket to the bolt. IT FITS PERFECTLY WITH OUT USING A SWIVEL !
I took off the top cover and expected the gears to be ground down to nothing or a pin broken or some visible sign of destruction....nothing, looks good inside. I poured some mercon on top of the drive assy and realigned the forks and popped it back together. Seems to be shifting fine now. Fingers crossed that it was just so dry the 4th gear syncro was just stuck.
The whole reason for my post was to give people a heads up to this transmission and find someone who knows that this thing exists. It's a 7L54 AB E476861 according to the sticker, and I found nothing on the Ford site or any specs on Google. The only info I found was from Zumbrota Drivetrains, RMTM5R1F-1TE Seems it is for the Mazda B2300 and is referred to as an M5R1
That's when I realized my MFD sicker on the door pillar says I have a type "R" transmission. Everything I was able to find says that's a R – 5R55W – 5-Speed Automatic (2002-2011). Definitely not a swap...it came original like that. I've included a few pics including the bolt pattern of the bell-housing. 10 Bolts hold it to the engine. If anyone has any info they can share or point me too it would be appreciated.
I will post again after put it back in and try it to let you know the results.
