snoranger
Professional money waster
ASE Certified Tech
- Nov 25, 2007
- 13,652
- Jackson, NJ
- '79,'94,'02,'23
- All Fords
- Engine Type
- 2.3 EcoBoost
- 2WD / 4WD
- 4WD
- My credo
- I didn't ask for your life story, just answer the question!
There’s SO much wrong with this entire comment that I’ll just list what I agree with...I've found out that the First Gen rangers with the 4.0 engines with 5 speeds are the best trucks to own so from 1991--1994. This can be 2 wheel drive or 4X4 modals.
1#
Here are a few reasons One is the 1989--94 late meaning it has to have the old Dash from 1989 Is the Heater core change out 20 mins for 1989--1994 heater core swap
The 1995 up Are piles of Scrap when it comes to being easy to do a heater core swap 1995--2099 it will take you 8-10 hours to change out and put back together. That is the one true reason why to turn these trucks into Baha trucks.
2#
In 1995 the 4.0 got the EGR put back on the rangers In 1990-1994 the 4.0 did not have the dreaded EGR valve. 1996 OBD2 came out How can I say this for all you people that hate check engine lights. 1996 ranger and up to 2014 You fart wrong in the seat the check engine light comes on. When you invite more government into your car or truck means more money out of your pocket. Plain and simple.
1990--1994 rangers with the 4.0 was the best bang for your dollar. One problem that all rangers had was that pile sh-t automatic transmission that Ford put in their rangers.
The Automatic was built for the 2.3 it was not meant to pull heavy loads and It was made for the small Mazda B2000 trucks the ford Mustang got the better trans as in the AOD That was a better towing and hauling transmission.
The 5 speed that came in all the years of Rangers where Gate the 4.0 Had the best 5-speed trans.
3#
1989--92 had the better body lines Plus they had drip rails above the door Easier to work on I own 5 of them 1990 ford Ranger extended cab XLT 4.0 auto 1991 ford ranger extended cab 4.0 5 speed 1991 ford explorer 2 wheel drive 4.0 5 speed 1994 4x4 4.0 5 speed 1996 2 wheel drive 2.3 5 speed extended cab.
The 1996 ranger has been the biggest pile I've ever bought spent well over 3500.00 to get it to pass smog An it won't New engine all new smog parts The 2 modules one for the EGR and the #2 downstream O2 sensor will not clear Put 5 of each on this truck finally bought a ford EGR valve for 325.00 It still Not cleared So I tell you all stay away from OBD 2 car's and trucks Buy new trade than in every 3-5 years stay in debt
The M5OD is the better trans to have.
