White residue on dipstick.
1984ranger28
5
Davison, Michigan
2.8l
Hi, now that winter is over I've been driving my Ranger more often. For the past week there has been small traces of white residue on the dipstick, it does not appear to be mixing with the oil. The oil is clear, no milkyness. No smoke out of the exhaust, no overheating or coolant loss, and good vacuum that doesnt fluctuate (20.5 Hg). I only drive to school in about 17 minutes. Is this not enough time to allow the engine to warm up and have any condensation evaporated? Thanks, Lucas.
rusty ol ranger
2.9 Mafia-Don
7,485
Michigan
177 CID
If youre not loseing coolant then its more then likely just condensation.
1984ranger28
5
Davison, Michigan
2.8l
Alright, thats what I figured. Thanks for the response.
8,370
Yes, condensation, change PCV Valve and check Vent/breather hose to make sure its clean
PCV system helps keep moisture levels lower in the crankcase valve cover areas, so less condensation
Also if engine does repeated short run times, under 10minutes, then condensation can increase, engine never gets hot enough to burn off water vapor
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
You might want to let it idle for a few minutes before you go to work. Get it up to operating temperature and vaporize those water molecules
