Wire terminals for harness clip that connects to Ignition Control Module (91 3.0)
misterW
4
I have a 91 3.0 that I've been trying to figure out why it has no spark. I narrowed it down to the ignition control module because the ICM was getting a pulse signal in from the distributor but was not sending it out to the coil. I replaced the ICM and still have the same issue. On closer inspection of the harness clip that plugs into the ICM, the terminal end of the wire in question appears corroded and damaged. I saw that I can solder in a new clip w/ 6 wires in place from Summit, but it costs $25, and I figured if I can just replace the 1 bad terminal, why not just do that. Know anywhere where I can find the type of wire terminal ends that are in that harness clip?
8,370
Wrecking yard, Ford used the TFI modules from around 1983 to 1995
Your 3.0l used Remote mounted TFI module, many used TFI mounted on the distributor, but TFI module's 6-wire connector was the same
There were 4 different TFI modules, seen here: http://www.myo-p.com/Ford-EEC/EEC Help files/Stolen graphics/compare_TFIs.gif
Grey and Black colors are the big thing, different wiring on the connector(pin 4) but SAME connector so you can use either one
