Yard cleanup
white trash
New member
Venus, PA
I need to get this stuff out of my yard.
I have 2 Rangers and and Explorer.
1. 89 Ranger 4x4 Supercab- 2.9, world products heads, JBA chrome headers, 4.10 D-28 & 7.5 with Lock right lockers, 5 speed M5OD from 4.0, 4.0 clutch, 4.0 radiator, steel ladder rack, aluminium tool box, and all the rust you can handle. It is basically just a pile of parts, the body and frame is rusty. $800
2. 91 Ranger 4x4 Supercab- 2.9 stock, D-35 & 8.8 3.73 i think, frame isn't too bad, body isn't too bad, aftermarket radiator support not installed, and light weight snowplow. This one could be put back together needs new cab mounts the bed is not great but isn't completely rusted out. $500
3. 01 Explorer 2wd- 4.0 auto, needs some body work, 4.0 motor from 96 partial rebuild. $400
4. misc stuff- tailgate $25, sliding rear window gen 2 supercab $100, M5OD $100, transfer case $50, pedals to convert auto to manual $25, there is probably other junk to be had too.
All vehicles ran when parked, they have been siting and will need some love.
I will not pull parts or ship, all are located In Venus Pa. 16364.
Thanks,
Brian
Rock Auto 5% Discount Code: 248EE46702D889 Expires: October 1, 2019
white trash
New member
Venus, PA
Prices are negotiable, I would like someone to use what they can.
I can't hold the wife off too much longer, then they will be scrapped.
Uncle Gump
Well-known member
524
Plano IL
Lead, Follow or get out of my way
Is that a snoway blade?
Do you have the headgear?
Did it work?
Are you willing to sell just that?
white trash
New member
Venus, PA
Did it work?
Yes I believe it is a Snoway.
It will need new hoses, they look pretty rough. It did work before I took it off of the truck. The headgear is on the truck yet, if you are willing to take it off you can have it.
I will sell just the plow, how much is it worth to you?
Thanks,
Brian
Uncle Gump
Well-known member
524
Plano IL
My plans for the future have changed a bit and I will end up with a tractor most likely.
I maintained a small fleet of plow trucks for several years and there was a small Blazer with a Snoway on it. Thing was lightweight and what I liked was that blade has power down... made a perfect set up for getting into tight spots and back blade those areas out. I don't remember it giving me any trouble over the years... other then replacing the cutting edge.
For anyone in that area that is tired of being on the end of a shovel after it snows... this would make a pretty nice homeowner set up. I would still hate to see it end up in the scrap yard.
