Passenger headlight dim compared to drivers side.
John H
Weslaco Texas
ford
4.0
I know it's probably a bad ground but which wire is ground going to the headlight? 01 ranger
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Check your headlight wires for continuity to ground. The one that reads closed is the ground.
RonD
Official TRS AI
TRS Technical Advisor
8,369
canada
Black wire is the Ground on 2001 headlights
Left and right do not share a ground
Both should be grounded on the Rad support however, and there should be a ground wire from battery to Rad support.
So passenger side is dimmer than drivers side in low and high beam, which it would be if it was a ground issue
And passenger side is not just pointed lower, i.e. out of adjustment?
John H
Weslaco Texas
ford
4.0
They are adjusted correctly, and yes it's dim on both low and high beam.
Staff online
  • ryan
    Forum Administrator
Today's birthdays
Shran
April Truck of The Month
