93 Ranger 4.0 4x4, XLT - rotor removal
montydaweasel
I am trying to replace the rotors on my 93 4.0L 4x4 5-spd with manual locking hubs. I got the hub wrench, and I loosened the first nut, but behind it there is a single washer and then another 4-prong nut. I am stumped. Please advise how to get the rotor off without destroying the wheel bushings?
mht95ranger
Ma/NH border
You need to pull the washer and other nut off to get the rotor off.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Yep... The washer should pull off, and then there is a second almost identical nut behind it that should only be about finger tight. The inner nut has a small nipple on it... MAKE SURE you take note of this, as it locks into the middle washer upon reinstall!!!!
Good luck!
