M5R1 shifter: rebuild stock, Core, or Hurst?
curtis73
6
Harrisburg, PA
Mazda
Common thing... shifter is sloppy.
Thoughts on new bushings in the stock shifter?
How about a Core shifter?
Or a Hurst?
Which one to do?
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
The rebuild kit deal for the stock shifter is pretty cheap.
Core is building new short throw shifters with Hurst parts for a couple hundred dollars.
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
Just get the rebuild kit. The aftermarket shifters aren’t vented and cause more issues down the line. Plus it’s a ranger. The stock shifter will prolong the life of the trans by NOT allowing speed shifting. Spend your money elsewhere.
curtis73
6
Harrisburg, PA
Mazda
Good point.
Are there upgraded bushings, or just stock replacements that need to be done every 50k?
Delrin? Aluminum? Bronze?
85_Ranger4x4
17,821
SW Iowa
Stock replacements are cheap enough and easy enough to change I wouldn't bother with "better" ones.
The kit is like $15 on Amazon.
curtis73
6
Harrisburg, PA
Mazda
Did the bushing repair. Much better. Still a bit of a long throw but at least not in the glove box.
