View Single Post
Old 10-03-2007, 03:20 PM   #33
Ranger5.0
Ranger5.0's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: DD, Wheeling,
Ranger5.0 is an unknown quantity at this point
Default
sounds like a good plan. Damn'd grounds can cause a lotta issues...and intermitent problems caused by bad conections are an even bigger pain it the arse.. Once ya start looking at your wireing, take your time, gently pull on some conections, see if anything looks bad. IF you cant solder and heat shrink the new conections, you can use crimp conectors that are coated with heat shrink tubing...They work well, we use them at Deere if/when we cant solder conections.
__________________
" MAKG-If you're making a snorkel, you don't need anywhere near 3 inches. You're not going to be running drag races in a river"
93' EXT,on the second 302H.O 3" single exaust,Deltaflow 40/AOD/13-56/F-150 coils, Explorer/ranger leafs.
Ranger5.0 is offline   Reply With Quote
