brazing ?
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I did everything I think I'm supposed to do. I did use a paste flux and a flux coated filler wire. The cracks I got in the pan are called, based on what I read, liquid metal embrittlement. I think I got the pan metal too hot. Thanks for all the information.
joey74
16
Vincent Ohio
drain plug
you do know you can buy bolt in from auto part store!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Those things come with a 100% leak guarantee.
black_demon69
142
AZ
4.0l
Keep heat primarily on the plug not the pan and heat evenly
It is easier to show then to explain :icon_twisted:
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I checked on the bolt in drain plugs. The reviews weren't so good. People complained about leaking and the plug pulling apart as they were being tightened. Plus, the bolt in type stood up higher inside the oil pan thus allowing more fluid to remain inside the pan.
Kirby N.
March Truck of The Month
