Low power/low vacuum
fastpakr
2,832
Roanoke, VA
When I tear it all apart, I'll be borrowing a degree wheel and dial indicator to make sure it's correct.
fastpakr
2,832
Roanoke, VA
Since the front cover's coming off, I'm going to put in a new harmonic balancer instead of the one with 250k miles that's currently installed. Any feedback on the Dayco Powerbond 'Premium' ($60) vs 'Street Performance' ($160) units?
fastpakr
2,832
Roanoke, VA
Picked up the stock replacement balancer and a new motorcraft cam synchronizer. Had a conversation today with both the machine shop that did the work on the engine and COMP Cams. Both think I have the wrong cam somehow. Ugh...
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Longer pushrods, low vacuum, low power, everything is pointing that way. It would not surprise me one bit if it was the wrong part in the right box.
fastpakr
2,832
Roanoke, VA
Craig0320
225
Mississppi
Good lord .585 lift on that cam and its for an ls. No wonder you need longer pushrods and your power sucked. The E303's are only .498 with 110 lobe separation. Just absolutely sucks someone screwed you over.
85_Ranger4x4
17,833
SW Iowa
Really amazing it even ran as well as it did.
Funny it even fit really.
fastpakr
2,832
Roanoke, VA
Amazon is taking care of it. I'm glad - not sure I would have believed my own story from their side.
Craig0320
225
Mississppi
I have had nothing but good experiences when having to return items on amazon.
fastpakr
2,832
Roanoke, VA
Comp swears they don't produce cams for Trick Flow so the only explanation is a customer swapping the cam and sending it back to Amazon. Honestly, impressed at their packing job. I never had a hint that I was opening a box for the second time. Instructions, comp stickers, etc were totally clean and the cam looked mint. Frustrating, but at least Amazon is handling it at no cost to me
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
How's that correct cam working for ya? At some point I'm going to be looking into some power adders...
Craig0320
225
Mississppi
I know the new cam is in. I think there still is a few things to button up to get it running.
fastpakr
2,832
Roanoke, VA
That's correct - the camshaft is slid into place, but I haven't had much time to work on it since.
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
Understandable... my Geo Tracker blew a head gasket in July of 2017, I've had the parts for over a year, a 2 weekend project (pull head first weekend, get head serviced and installed the next weekend) has taken about a year and a half... and I haven't even touched it other than doing a compression test...
