Help with buying the right back spacing.
Sweet-85'
Hastings, MN
Ford Bronco II
2.8 V6
2.8L 171CID
If it ain't broke, fix it 'till it is!
Hey y'all, looking for some help selecting the right back spacing for my setup.
I'm going to replace the 31x10.50's on stock 5.5" rims on my bronco II with a set of 32x11.50's on new 8" rims.
Right now the truck is pretty squirrely at highway speeds, which I attribute some to the removal of the sway bars. But, I think a lot has to do with the narrow track of the stock wheels, and sidewall roll of 31's on stock skinny wheels.
looking at these wheels: https://www.summitracing.com/parts/clm-5375812-3/overview/
I am wanting a little wider track with these 32's, what backspacing should I be looking at? I was initially thinking 3" to 3.75", but I really don't know. Any help would be appreciated!
I think you may have other issues contributing to your poor handling.
I know the B2s can be squirrley due to high COG, narrow track width, and short wheel base, but my Ranger has 31x10.50s on those exact rims and I have no tire-related handling issues (or really any at all) at high speeds. Consequently I would look at other things like tire inflation and worn/damaged steering and suspension components before suspecting the combo of wheel and tire.
Sweet-85'
Hastings, MN
Ford Bronco II
2.8 V6
2.8L 171CID
Well, I am still looking at 32's anyway...
Sweet-85'
Hastings, MN
Ford Bronco II
2.8 V6
2.8L 171CID
What backspacing are some of you running? The point is I will be buying 32's and could use a little help. I've seen 3.75" mentioned a few times, seems pretty common. Anyone have pics of your setups (1st gen) with backspacing?
Thanks again!
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Have you looked at the documentation in the "How To" section here on the site?
Do you have a suspension lift? Body lift? Both? This is a guide to get your BII to clear 32 inch tires....
https://therangerstation.com/how-to_pages/ford_ranger_tire_fitment.shtml
I think your stock wheels are probably 7 inches wide with a 4.5 inch backspace. Going with an 8 inch wheel and 3.75 backspace will widen your stance but will increase your chances of rubbing with the suspension flexed and turning the wheels from lock to lock.
Sweet-85'
Hastings, MN
Ford Bronco II
2.8 V6
2.8L 171CID
Thanks, that's what I was looking for, I already planned on trimming the fenders. It has about 2.5" of lift now. I had seen 3.75" used quite a bit, but wanted to be sure. My stock wheels are of the 15x5.5 variety, pretty skinny, but I'm not sure of the backspacing, probably 4.5"
Edit: just found the wheel fitment guide, and looks like 3.75" is recommended for an 8" wheel (explains why I see that number so much). Thanks for everyones help, I'll post the finished product...
