1996 xlt questions!!
Ramonjportilla
Hey guys new to trs, love the info I have already gained! I have a 02 door on my 96 xlt and it doesn't fit properly. What doors are interchangeable? Maybe I installed the door wrong, or maybe I'm not doing something right. Please any info will be a big help!!
XLTsplash
160
CA
2.3L
The door should fit. What part of it are you having a problem with ? There is adjustment between the door and the hinges, the hinges and the body. There is also adjustment at the door striker.
Ramonjportilla
There is a gap between the door and the body at the top of the door and by the front fender. So a 2002 door fits on a 96? I know the fender is wrong but I had it so I just threw it on thee until I could find a 96 fender. I'm thinking that I need to adjust my hinges somehow. The door will shit but you have to make it want to shut of you know what I mean.
XLTsplash
160
CA
2.3L
You should be able to adjust the door for a good fit. There is adjustment between the body and the hinge, between the door and the hinge and at the striker. You just have the loosen the bolts and move the hinges. The hinge bolts are a little hard to get to. If you had the fender off the hinge bolts would be very easy to get to. You can adjust the door to the body, then put the correct fender on and adjust the finder to line up with the door and hood.
Ramonjportilla
Thanks buddy!
