Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-08-2017, 04:41 PM   #1
broncobuckinaround
Vehicle Year: 07/86
Vehicle Make: ford
Vehicle Model: bronco 2 4.0
I use this vehicle for: everything and anything
broncobuckinaround is on a distinguished road
Default Compression ratio
Stock 91 f350 460 compression ratio. I can find it.
Anybody know what it is.
broncobuckinaround is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 11-08-2017, 05:08 PM   #2
alwaysFlOoReD
Super Moderator
alwaysFlOoReD's Avatar
Vehicle Year: '91, '94, '80
Vehicle Make: Ford, GMC
Vehicle Model: Ranger, Ranger, Grumman Kurbmaster
I use this vehicle for: 4x4 race, 4x4, Work
alwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud of
Default
WAG; 8.5-1
I don't know but am interested as well.
My 68 c8ve is about 10.5-1
__________________
My aspirations; Good thoughts, Good words, Good deeds.
alwaysFlOoReD is offline   Reply With Quote
Old 11-08-2017, 08:28 PM   #3
pjtoledo
Vehicle Year: 2000 2005 199
Vehicle Make: Fords
Vehicle Model: Rangers Taurus SHO 5spd
I use this vehicle for: going to Cabelas
My credo: get outta my way, I'm falling!
pjtoledo has a spectacular aura aboutpjtoledo has a spectacular aura about
Default
Quote:
Originally Posted by alwaysFlOoReD View Post
WAG; 8.5-1
yep, 8.5:1 per Chiltons
pjtoledo is offline   Reply With Quote
Old 11-08-2017, 10:45 PM   #4
broncobuckinaround
Vehicle Year: 07/86
Vehicle Make: ford
Default
This would be a good thing if it is. Because it means I can either put flat top pistons in or deck the heads til it would be at least 10 to 1
Old 11-08-2017, 11:06 PM   #5
alwaysFlOoReD
Super Moderator
Default
I've been trying to figure out what to do with my 68 460. The high compression means premium fuel and I can't afford that. While looking for some other parts I stumbled on a propane system that I had squirreled away. Ding! I have a non-running very high mileage van I use for storage that has a complete propane system. IIRC propane will support up to 13-1 compression.....the wheels are turning....
__________________
Old 11-09-2017, 01:47 AM   #6
broncobuckinaround
Vehicle Year: 07/86
Vehicle Make: ford
Default
wont you loose a ton of power tho. propane will last longer but you sacrifice power. correct me if im wrong
Old 11-09-2017, 09:44 AM   #7
alwaysFlOoReD
Super Moderator
Default
Propane is less btu than gas, but you can run much higher compression ratios than with gasoline. If the motor is built for propane you can get almost as much, if not equal, power.
__________________
Old 11-09-2017, 01:46 PM   #8
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
Octane = 8(oct) carbon molecules with 18 hydrogen molecules, and is a very stable chemical "string"
If there are less then 8 carbons in the "string" it becomes less stable, easier to break apart, i.e. ignite
Octane rating is the amount of stable strings in the volume
Gasoline runs 87 to 92 octane
Propane 104 to 112 octane
Octane is not power related, just the rating of 8 carbon strings
Compression is heat, it is also power, like winding a rubber band, more winding releases more power.
With too much heat low octane fuel will self ignite, so 87 octane gasoline needs 9.4:1 or lower compression ratios
Propane does have less stored energy per "gallon", but with it's higher octane rating it could be used in higher compression engines to balance that out, but then that engine couldn't run 87 octane gasoline.
Diesel uses Cetane(Hexadecane) rating, 16 carbons with 34 hydrogen also a very stable string and also harder to ignite
RonD is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What pistons for best compression ratio. Haywire6000 Forced Induction 1 12-15-2015 08:22 AM
Compression Ratio Ranger4x4newb 4.0 Liter Forum 1 11-14-2015 03:37 PM
4.0 ohv compression ratio dahunter_2007 4.0 Liter Forum 9 05-27-2013 09:31 AM
compression ratio 92ranger18 Forced Induction 15 08-24-2012 09:25 PM
Figuring out compression ratio HoleshotKFX400 V-8 Conversion Forums 7 05-17-2008 07:49 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
