Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Communications
Notices
Communications This forum is for CB & HAM radio, cellphones, PDAs, in-cab computer installations and GPS.
Reply
Thread Tools Display Modes
Old 08-16-2017, 09:50 AM   #1
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: High Performance Commute
chewy012 has a spectacular aura aboutchewy012 has a spectacular aura about
Default CB antenna ground
Just put a CB in the ranger. Mounted it to the bed tool box, which is bolted to the bed, which is bolted to the frame.... Which is bolted to the battery.
Is that a good enough ground? Should I run a wire straight to frame?
The antenna is only a 22", but it sits above the cab line by 6-8" in the center of the truck and clears the radio antenna by an inch.
Does it need to be raised?
Sent from my XT1254 using Tapatalk
__________________
4.0L OHV, M5OD, 3.08 Rear, 205/75R14, K&N, Stock.
chewy012 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-16-2017, 01:39 PM   #2
AzLizard
AzLizard's Avatar
Vehicle Year: 1994 1985
Vehicle Make: Ford
Vehicle Model: Explorer Ranger
I use this vehicle for: DD offroad
AzLizard will become famous soon enough
Default
Did you use the antanna mount with the nylon bushing?
https://www.peterbiltparts.com/elect...RoCW64QAvD_BwE
__________________
85 reg cab ranger/samurai xcab project
99 b2500 2wd daily driver
94 4dr explorer
AzLizard is offline   Reply With Quote
Old 08-16-2017, 01:55 PM   #3
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Default
No, it came with a gutter mount clip (metal). I replaced that with a stainless L bracket. The base is mostly plastic, but has metal sections for contact with original metal bracket and coax.
__________________
Old 08-16-2017, 06:05 PM   #4
AzLizard
AzLizard's Avatar
Vehicle Make: Ford
Default
That nylon washer keeps it from grounding.
__________________
94 4dr explorer
Old 08-16-2017, 08:43 PM   #5
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Default
Quote:
Interesting, I would've expected it to need grounding. I'll through an isolator in there.
Thanks!
__________________
Old 08-17-2017, 10:29 PM   #6
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
The antenna bracket itself must be grounded (bolted directly) to the toolbox, bed, whatever large metal surface it is attached to. The insulator is to keep the center radiating element (antenna itself) from grounding out against the bracket. So you would put the stud piece (w/star washer) through from below the bracket, then on top goes the nylon washer (shoulder facing downward into the hole), the flat steel washer (if one is present) goes next, and then the threaded sleeve that holds it all in place. Finally the antenna screws into the sleeve.
Indeed it needs to be (much) taller, but not by raising it's mount up...
The antenna itself is what needs to be taller (antennas that short IMO are a scam, they work so poorly). The longish 11-meter wavelength at 27 MHz (the radio spectrum CB uses) requires an antenna at least 48" tall in order to work at least somewhat acceptably (60-66" is much better, with a quarter-wave (102" tall) steel whip being best). Unfortunately there aren't many resources that tell you this though (or that at least make clear how important it is), which is partly responsible for the bad rap CB units seem to have gotten lately.
I run a 5.5' (66") Francis CB-26 Hot-Rod antenna w/heavy-duty spring on mine.
http://www.amazon.com/Francis-300-CB.../dp/B007QXLS82
http://www.amazon.com/Firestik-SS-3H.../dp/B00042LC9M
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 08-18-2017, 07:16 AM   #7
AzLizard
AzLizard's Avatar
Vehicle Make: Ford
Default
What he said. Lol
__________________
94 4dr explorer
Old 08-18-2017, 07:36 AM   #8
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Default
Awesome, thanks for the all the information. I know the 22" isn't good, but it was free from dad haha.
Looks like I'm in the market for an antenna!
__________________
Old 11-18-2017, 07:53 PM   #9
Dangerrangers
Dangerrangers's Avatar
Vehicle Year: 94 and 04
Vehicle Make: Ford
Vehicle Model: Rangers 4/4s 4.0s
I use this vehicle for: DD/Wheeling
My credo: Do it right the first time !!!!!!!!!!
Dangerrangers is on a distinguished road
Default
Check the truck stops they have a cb section with lots of cool stuff.
__________________
NRA member 35 years / Trump Supporter
Union Ironworker 40 years/Certified Welder
Proud American and Patriot
Low budget wheeler build . 4.0 / 5 speed , cam , headers , lockers
Dangerrangers is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Antenna? gungfudan Stereo & Video 1 10-10-2012 05:04 PM
cb antenna tie down schneiderz Communications 4 08-12-2011 04:13 PM
Antenna ? spikebrian Communications 3 11-06-2009 06:01 PM
Antenna keane728 Stereo & Video 1 10-14-2009 08:18 PM
cb antenna larsen101 Misc Electrical & Gauges 4 03-13-2009 01:52 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
