Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Reply
Thread Tools Display Modes
Old 08-16-2017, 02:44 AM   #121
mavereq
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: 97 Ranger, 84 Mustang SVO, 88 Turbocoupe, 70 bronco
mavereq is on a distinguished road
Default
The headers that bcbroncos sells might work
mavereq is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-29-2017, 03:16 AM   #122
Bird76Mojo
Bird76Mojo's Avatar
Vehicle Year: 2001 & 1987
Vehicle Make: Ford
Vehicle Model: Ranger Edge 4x4 - 87 302 swap
I use this vehicle for: Everything!
My credo: Good enough
Bird76Mojo is on a distinguished road
Default
Well, I ordered the 88400's so we'll see how they fit in an 87 standard cab 2 wheel drive soon enough... If not, I'll mod them until they do fit. I have an entire stainless system to hand fab at the same time also. Looking at TIG machines now.
GB
__________________
2001 Ranger 4.0 4x4 REG CAB Edge 4.10LS SL'd 33's * 1987 Ranger reg cab shortbed w/ 92 5.0 & T5Z * 89 Ranger 2.9 5spd 4x4 longbed (retired) - 89 Bronco II X 3 (parts)
Bird76Mojo is offline   Reply With Quote
Old 12-07-2017, 10:32 AM   #123
marioms1
Vehicle Year: 99
Vehicle Make: ford
Vehicle Model: ranger
marioms1 is on a distinguished road
Default mustang headers?
will the stock mustang headers work?
marioms1 is offline   Reply With Quote
Old 12-07-2017, 12:12 PM   #124
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
Quote:
No.
SN-95 will work on the DS but the passenger side is the same as a Fox where it points directly at the frame.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0HO, M5R2, Twin-Stick NP205, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is offline   Reply With Quote
Old 12-23-2017, 09:17 AM   #125
Loganwildman
Vehicle Year: 1994
Vehicle Make: Ford
Loganwildman is on a distinguished road
Default
For those installing long tubes, do you install them when you set the motor in, or after installing the transmission?
Loganwildman is offline   Reply With Quote
Old 12-29-2017, 03:38 PM   #126
benhojnowski
Vehicle Year: 1983
Vehicle Make: Ford
I use this vehicle for: Daily Driver
benhojnowski is on a distinguished road
Default
Make your own headers that exit outside the frame. Much better. less clearance issues. Speedway Motors has a weld up kit for SBF for $150. on sale now for $115. Comes with plenty of pipe, Collectors and flanges. I used it on my 351W swap recently.
https://www.speedwaymotors.com/Small...ctor,3842.html
benhojnowski is offline   Reply With Quote
Old 01-03-2018, 12:15 PM   #127
Ripind
Ripind is on a distinguished road
Default
You have a pic of those speedway headers welded up?
Ripind is offline   Reply With Quote
Old 01-04-2018, 05:07 PM   #128
benhojnowski
Vehicle Year: 1983
Vehicle Make: Ford
Default
No unfortunately I didn't take any picks after I made them, before installing. I do have this video of them on the truck. Passenger side was fairly easy. The drivers side I made the rear 2 headers pipes go under the steering shaft. The front 2 go over and they connect with some cheap flanges I bought. So the collector and rear 2 pipes are fully solid and go on first. Then the front 2 bolt together. It was time consuming but not at all that difficult.
https://www.youtube.com/watch?v=W7qOZYS-OI4&t=4s
Old 01-05-2018, 11:25 AM   #129
2Krngr
Junior Member
Vehicle Year: 2000 Ranger 2wd
Vehicle Make: Bagged Stepside
Vehicle Model: 5.0L Manual
I use this vehicle for: Street
2Krngr is on a distinguished road
Default
Outside the frame is an option for Ibeam / Gearbox trucks, the Ibeam trucks have many header options, they are much easier to fab up or modify something to work.
Outside the frame will not work on a 98+ Control Arm / Rack and Pinion truck.
__________________
2000 Supercab Stepside / 2wd 5.0L V8 5-Spd / Bagged & Z'd
FOR SALE: Mazda B2500 5-Spd Lowered/8.8 LSD/Rear Disc/Cobra Wheels -> http://www.therangerstation.com/foru...d.php?t=177837
2Krngr is offline   Reply With Quote
Old 01-05-2018, 04:12 PM   #130
Bruce2
Bruce2 is on a distinguished road
Default
I used tri Y's on my 351 install into a 1988 2 wheel drive regular cab with AOD..had to do some modifying of the steering shaft and notch out the frame on passenger side.
http://www.therangerstation.com/foru...=173117&page=2
Bruce2 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
