Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
Notices
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 12-07-2017, 06:36 PM   #1
RangerJ
RangerJ's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 4X4 XLT
I use this vehicle for: Outdoor Stuff
RangerJ is on a distinguished road
Default 2002 4x4
I am still looking to buy another Ranger,this time I have found a 2002 4x4,auto trans,appears to be in good shape based on pics.Was this a good year for the Rangers,If anyone has any advice please share with me.Thanks
RangerJ is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 12-07-2017, 10:35 PM   #2
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
I don't think there were "bad" years for Rangers, except 2013 and up
2002 had 3 engines offered
2.3l DOHC 4cyl Duratec, had heated thermostat and IMRC issues
3.0l Vulcan, reliable but under powered V6, used from 1991 to 2008 in Rangers, so a good "little" engine
4.0l SOHC, had timing chain issues until 2004 model year
Automatic transmissions are tricky in used vehicles, nothing to do with Ford, Chevy or ??.
How they were used and maintained decides "miles to go" before rebuild is needed, same as Clutch for a manual trans, parts DO WEAR OUT
2002 used 5R44E in 2.3l and 3.0l, 5R55E for 4.0l
No real fingers to be pointed at anything specific on these for 2002 model year
4WD Rangers used 4x4 control module in 2002, these were known to fail, I would not say "common", just a known issue.
2002 will have PATS(passive anti-theft system), PATS keys are needed to start the engine
Check fluids, smell fluids.
Make sure Check Engine Light(CEL) comes on with the key, then goes off and stays off after startup
Ask to see the Title, you don't want to pay full fair for "rebuilt" or "salvaged" title
Ford has a very good "Used vehicle check", runs about $150
See if seller will allow you to pay for this test, if not you may want to rethink this one, could just be seller doesn't want the hassle of you taking it in, but he could also be hiding something major.
RonD is offline   Reply With Quote
Old 12-07-2017, 10:45 PM   #3
RangerJ
RangerJ's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Default
Thanks RonD,for your response and info.
Old 12-08-2017, 11:38 AM   #4
91stranger
91stranger's Avatar
Vehicle Year: 1999
Vehicle Make: FORD
Vehicle Model: RANGER EXT CAB 3.0
I use this vehicle for: daily driving
91stranger is on a distinguished road
Default
I agree with the above, most all older rangers were good. That's why they made so many rangers and that's why you still see so many rangers on the road today. Whenever I look at a car I start underneath. I live in Ohio so rust is a big factor in vehicles. You can learn a lot about a vehicle by looking underneath it. Check for rust on frame around the leaf spring mounts seem to be the worse spot. check the leaf spring hangers, those r common on all rangers. check the fluids. listen to the motor running while idling. see if it idles good and sounds good. ALWAYS check the title. you don't want to get burned on a title discrepancy like a salvage or rebuilt. That will change the price dramatically. I had a salvage vehicle and it had issue after issue after issue and tons of little things kept breaking that would just irritate you. so check for rust, fluid levels and what they look like, listen to that motor purr, check the title and drive it. If they don't let you drive it then don't bother. Probably got something seriously wrong with it.
__________________
1999 ford ranger 4 door, 2wd, tow package, 3.0 auto trans. sweet ladder rack.
91stranger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help with my 2002 3.0 Tomkat 3.0 Liter Forum 1 07-10-2014 08:53 AM
My 2002 XLT EERNGER 1983-2011 Off-Road & 4x4 Ford Ranger's 49 11-27-2011 10:17 PM
2002 3.8 kiragyu 'Other' Engine Conversions 1 06-17-2011 02:40 PM
2002 8.8 red02 Ranger Axles 4 04-27-2009 08:43 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
