Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Ford Ranger Mini Trucks (Street)
Notices
1983-2011 Ford Ranger Mini Trucks (Street) Instagram and facebook are ok, but it's hard for people to follow your build and the details. Show of your trucks, or post your build threads here.
This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 11-11-2017, 07:15 PM   #101
1qaz
1qaz's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Mind Restoration
1qaz has a spectacular aura about1qaz has a spectacular aura about
Default
Quote:
Originally Posted by Mark_88 View Post
Wow, you've been busy since the last time I checked.
Congratulations on the show placing too.........Keep up the good work~
Thanks Mark!
Old Parts Out!
Flywheel, clutch pressure plate, clutch disc -- Not too bad for 30 years of use.
Slave cylinder...it's seen better days
NOS Parts Ready to Go In
Clutch Pressure Plate - Remanufactured - $35...will remove the surface rust and fingerprints
Clutch Disc - $55
Slave Cylinder - $155 ... OUCH!
Pilot Bearing (still have to get the old one out) - $10
Wonder if my rear main seal leaks?!!
Got one of those, too! - $19
Total Costs = $274...so far
Still have to resurface the flywheel and add the cost of the transmission (which is still at the shop).
1qaz is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 11-12-2017, 05:17 PM   #102
1qaz
1qaz's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Adding an oil pan gasket change to the task list...leaking like a sieve at the back of the block...cleaned it up and let it sit overnight so the leaks would show themselves...two pretty good steady streams at the bottom.
Toasted!
Might as well add a new catalytic converter, motor mounts, and coolant flush as the engine has to be drained and raised about 2.5" to get the pan out, according to the Ford shop manual. While everything is out of the way, probably should take care of the exhaust manifold, too. Certainly won't be bored for a while.
Old 11-14-2017, 09:39 PM   #103
blackwidow67
The Vengeful One
blackwidow67's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: RANGER
I use this vehicle for: Doing ranger things of course!
blackwidow67 is a splendid one to beholdblackwidow67 is a splendid one to beholdblackwidow67 is a splendid one to beholdblackwidow67 is a splendid one to beholdblackwidow67 is a splendid one to beholdblackwidow67 is a splendid one to behold
Default
Gonna be better than New when you’re done!
__________________
1988 RANGER. Built 355 SBC. TH700R4. 3:73 Gears. BlackWidow Clone Build Thread http://therangerstation.com/forums/s...d.php?t=168398
1990 RANGER. Mild 5.0. T5 trans. 4.10 gears. Daily driver!
1999 Ram 1500 5.9. for work and play....... well mostly play
1962 CHEVY IMPALA SS CONVERTIBLE
blackwidow67 is offline   Reply With Quote
Old 11-21-2017, 02:29 PM   #104
McWillies
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
McWillies is on a distinguished road
Default
Just read through the whole build. Great looking truck!
Sent from my SM-G950U using Tapatalk
McWillies is offline   Reply With Quote
Old 12-02-2017, 09:07 PM   #105
1qaz
1qaz's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Quote:
Thanks!! I'm learning a ton...in up to my neck for sure. Chasing parts is taking the most time.
Quote:
Thanks!! Lots more to come.
The teardown continues....
Catalytic Converter....boy am I glad I have a good impact wrench!
Exhaust Manifold and EGR Tube
Radiator Shroud and Fan
I can now get after some of the previously inaccessible parts of the engine and bay.
And top motor mount nuts are off...unsure how to get at the bottom ones at the moment. With everything out of the way it's time to raise the engine and drop the oil pan.
Old 12-17-2017, 09:16 AM   #106
1qaz
1qaz's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Finally got to the oil pan...ended up using a chain hoist to raise the engine...it was way too unstable using a jack without the transmission.
Pretty clean on the inside
Total mess on the outside
Here's what's left of the gasket
Bottom end of the motor...wood block above the motor mount as recommended by shop manual...not needed with chain hoist but no way I'm not putting it there after all this
Also, transmission completely tore down
With new parts ready to go in
Transmission should be done in a week or so. Now to the clean up of all these other parts so I can put it all back together.
Old 12-22-2017, 10:11 PM   #107
1qaz
1qaz's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Ready to go back on...
Exhaust Manifold
Oil Pan
Old 12-22-2017, 10:26 PM   #108
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
Looks really nice.
It is amazing the effort they put into the four cylinder exhaust manifolds. In the same time frame V8's had manifolds that looked like a log with four branches in a row.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0HO, M5R2, Twin-Stick NP205, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is offline   Reply With Quote
Old 12-23-2017, 02:20 PM   #109
XLTsplash
XLTsplash's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT with splash added
I use this vehicle for: Weekend work and driving
XLTsplash will become famous soon enough
Default
Looks great !
XLTsplash is offline   Reply With Quote
Old 12-31-2017, 10:59 AM   #110
majorburns
majorburns's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: finding out new curse words and seeing just how deep my pockets go lol
My credo: the choices people make when no one is around reveals their true colors
majorburns is on a distinguished road
Default
just got done binge reading this entire resto and im hooked.. fantastic looking truck man
majorburns is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
