Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Non Truck Discussions > Non RBV Tech
Notices
Non RBV Tech For discussing tech other than Ranger related.
Reply
Thread Tools Display Modes
Old 12-28-2017, 08:25 AM   #1
Ranger4x4.0
Ranger4x4.0's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: DD. Weekend off-roader. Vacation road-tripper
My credo: God is great, beer is good, and rangers are awesome!
Ranger4x4.0 is on a distinguished road
Default 96 Olds Cutlass Trans Problem. Has me Puzzled!
I have a 1996 Oldsmobile Cutlass Supreme Coupe with a 3.4 V6 (LQ1) and a 4t60e transmission. First of all, this is why I don't buy a Chevy, or anything with an automatic, but i did...
The problem I'm having is when I'm in 4th gear (od) it feels very sluggish. I can't explain it exactly but I'll try my best. In 4th going 65 mph, it stays at around 2400 rpm, which is the speed the engine drops to when you let off the gas. I know this because it recently started doing this and I know that going 65 in the last gear (4th) the "deadzone" so to say, is between 2400 and 3000 rpms. Which means that when you are climbing a hill, it should rise up to no more than 3000 rpms in 4th gear going 65, but it stays at 2400. Now when I push the gas pedal down further than needed, it will go to 3000 like normal, but it will feel like and look like a downshift. And then it will go back down in the same manner. I scratched my head for a minute and I swore up and down this thing didn't randomly grow a 5th gear that acts like a manual tranny would, it didn't but made me have a blank stare for a second. When I manually shift it in 3rd, at certain speeds, it will do the same in 3rd gear, as if it shifts in 4th but it can't.
I should mention that I did check the fluid, it was low by a pint and a half, quit a bit I know. I filled it back up, no difference. The fluid itself seemed ok, not burnt, probably could use a change though.
This really has me puzzled, 1st and 2nd gear is fine. So if anyone has any clue or a guess, I would like to hear it! Tia.
Sent from my SAMSUNG-SM-G890A using Tapatalk
__________________
-1998 Ford Ranger 4x4 4.0 OHV, and loving it!
https://www.youtube.com/channel/UC3g...hJrZ4MOQ0cbysg-vids of my ranger! new videos every week! Some random videos here and there. Subscribe!
Ranger4x4.0 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 01-02-2018, 11:15 PM   #2
Bruce2
Bruce2 is on a distinguished road
Default
Torque converter lockup..when you step on gas hard enough it will unlock feeling like a downshift and when let off gas or load is lessen it will go back into lock up, same for 3rd gear, lock up will come on in manual 3rd.
Bruce2 is offline   Reply With Quote
Old 01-09-2018, 08:38 AM   #3
55trucker
55trucker's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
I use this vehicle for: My Ride (or should I say...the Wife's Ride)
55trucker is on a distinguished road
Default
Hmmm.....with this particular drivetrain the engine should be at 2000rpm in 4th..and at 65mph the converter locked up. If you're at 2400rpm my first thought would be that you're actually in 3rd/converter is locked or the converter has not locked up in 4th. This is relatively easy to determine as when you apply mild throttle if the converter IS locked up the engine rpm will not climb freely as it will when the converter is unlocked.
Converter lockup with the 4t60E behind the DOHC takes place at just below 80kmh/50mph, seeing as you're OBDII are you seeing any sign of a code flash up on the check engine light?
Another possibility is the 02 sensor is on the way out and the PCM cannot properly command a converter lockup, you'll feel a continued lock/unlock mild shudder driving at speed. If the PCM CTS is giving an incorrect signal (low) to the PCM this too will upset the ability to go closed loop preventing converter lockup keeping the fuel system open loop that also will not allow proper converter lockup.
any codes?
if you manually select 3rd the trans will not go into 4th at all but you will get converter lockup. Are you getting any hard upshifts at all, that would be a sign that the vacuum modulator is in question.
__________________
Steve
55trucker is offline   Reply With Quote
Old 01-09-2018, 08:52 AM   #4
Ranger4x4.0
Vehicle Year: 1998
Vehicle Make: Ford
Default
any codes?
I should mention also, it seems like it only does it when it's below 25°f, when it's warmer outside, it will act perfectly fine.
The codes that I can remember are cylinder 1 misfire, something about engine wiring harness? And an evap code that went away after replacing gas cap.
__________________
Old 01-09-2018, 12:04 PM   #5
55trucker
55trucker's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
Default
How recent is/was that P0301 code?
That may be your sluggish state right there.
Faulty plug, faulty plug wire, coil pack may be laboring, #1 injector at fault,
If you want to get further info on the DOHC you could consider joining 60degreev6.com, all GM 60 degree *6* engines are covered. Also there is w-body.com, we're all Grand Prix, Regal, Cutlass, Z34, Lumina, Monte Carlo SS, GXP G8 followers.
__________________
Steve
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
olds one ton...hmm 86MUDRCJ Non-Ranger Axles 5 12-17-2011 07:56 AM
455 olds in a 95 ranger JunkYardRanger 'Other' Engine Conversions 9 10-23-2009 12:21 AM
weird problem-puzzled rangerrager 4.0 Liter Forum 18 04-30-2009 08:56 PM
Opinions: Olds Van firefighter525 Non RBV Tech 5 04-23-2009 08:35 AM
Hmm...455 Olds Rocket? rusty ol ranger General Discussions 17 03-20-2008 08:26 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
