Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Notices
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 01-03-2018, 01:23 AM   #1
AnahRabekka1501
AnahRabekka1501's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger XLT Supercab
I use this vehicle for: Daily Driver. Restoring & Modernizing
AnahRabekka1501 is on a distinguished road
Default I donít know what is happening, and Itís scaring me.
I have a 1989 Ford Ranger Xlt Supercab. Thatís the easy part. Hard part is trying to figure out what the hell is happening. Let me break it down.
1. Turn signals make my oil pressure needle flutter back and forth with the clicking.
2. My Drivers headlight is dim as mess, like super yellow, while my passenger side is good. I also have zero high beam in the drivers side.
3. My headlights are so out of alignment that they donít help me at all when driving. How can I adjust the angle?
Thank you for reading and all the help I hope to receive. I really donít need more problems with this truck, Iím trying to make it better and build it into a nicer rig.
__________________
1989 Ford Ranger XLT Supercab
~Modernizing and Restoring
~Heavy on the Modernizing part!
AnahRabekka1501 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 01-03-2018, 01:56 AM   #2
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Vehicle Make: Dordge
Vehicle Model: Care A Van
I use this vehicle for: Space travel
My credo: Love Thy Neighbor
Mark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond repute
Default
Sounds like a few things going on....
Sounds like a bad ground somewhere...that may take a bit of searching for the source...did you do any work recently like installing a radio, splicing wires, patching in wires to the fuse panel?
If so and this started happening just after...backtrack and check your work...otherwise check your grounds for corrosion...battery cables...loose connections on the battery or the solenoid on the fender where your battery connects to the starter circuit...tighten, clean, replace damaged wires.
High beams may be the bulb needs to be replaced...if the low beams work...and the dimming may indicate the bulb also...it is just about ready to go out...simple to replace them...go to a junkyard and grab some spares...they don't usually charge for them or very low price...I always grabbed spares when going in for other things...
Otherwise could be another wire/socket issue...if replacing the bulb doesn't fix it check the wires...back to any connections in the harness...maybe a bare wire that is shorting out...
3. My headlights are so out of alignment that they don’t help me at all when driving. How can I adjust the angle?
There are adjustment screws that you can use to align them...they are on the side and bottom of the lens on each side...star screw driver will adjust...spray the adjusters with some penetrating oil before doing anything...if they are too badly rusted you may need to do a bit of cleaning...if they look clean check the alignment before doing anything.
I used to drive up to a wall or garage door (nonreflective) and park about 5 feet away...best done at night...see where they are aimed...if you can't tell that then you may need to check with a mechanic but they are not hard to adjust or determine their aim.
If you can, adjust them so they were slightly off to the right towards passenger side and the beam was pointing level with the hood or slightly downwards...you don't want to blind the traffic coming at you and don't want them too high or too low...you can see approx where they are pointed on the wall by the way they focus...
EDIT: If your lenses are dirty you can clean them...check this thread for tips on cleaning...
http://www.therangerstation.com/foru...d.php?t=174782
I used the method of wet sanding and clear coat spray but there are others that work just as well..
Not a lot to fix but certainly can be frustrating when they all happen at once or the show up around the same time...but you get used to it...and it's fun to be on top of it.
__________________
Rome and my Ranger were not built in a day...
1988 Ranger 2.0 5 spd (gone)
1988 Ranger 2.3 " (gone)
1996 Ranger 2.5 (gone)
On-line manual link
http://www.therangerstation.com/foru...94#post1581294
Mark_88 is offline   Reply With Quote
Old 01-03-2018, 09:17 AM   #3
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Go get your alternator checked. Aside from what is probably a bad bulb (you do know they burn out from time to time, right?) most of what you have described is either a grounding issue, as Mark suggested, or a weak/failed alternator. Most parts stores offer free alternator testing, both on and off the vehicle, and while you are there you can pick up some headlights (always replace the bulbs in pairs) and maybe some of that headlight restoring stuff (how oxidized are your lenses?).
The fact that the oil pressure gauge is involved suggests a grounding issue. The way the gauge works is that power flows through the windings at the needle, down to the pressure switch, which grounds the gauge, through the block, when pressure is applied. If adding a load to the system makes it act funny that suggests there is an issue with the ground circuit. An easy way to test this is to hook a jumper cable between the engine (alternator or power steering brackets are good spots to get a good connection) and the battery negative. Then start the engine and turn the turn signals on. If the issue is no longer present go get some battery cables, one with a terminal end, and one with two eyes. Replace your negative battery cable with the terminal one, and run the other between the engine and body.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 03-22-2018, 10:04 AM   #4
AnahRabekka1501
Vehicle Year: 1989
Vehicle Make: Ford
Default
Thank you both. I’m still working on the grounding issue, but I’m probably going to do the two wire solution adsm08 suggested. I finally found the alignment threads for the headlights, they are at least better now. And it was the bulb. I got some $9 hella bulbs off amazon and threw them in, problem solved. Downside, everything in this truck is dryrotten so i broke the clip on the bulb plug. Found a replacment, just havent ordered yet. And i knew it wasnt an oxidation issue, the assembly themselves were brand new in 2012.
**I thought it was the alternator too, but I got a battery checker from walmart and my alternator is putting out some decent charge. It was replaced back in... 2003? 2006?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2016 Ford Bronco Itís finally happening! 96Indyram General Discussions 13 02-11-2016 11:01 PM
WTF is happening here etopsirhc General Discussions 6 07-14-2012 02:40 PM
Now its Scaring me mattpresley 2WD Lifted / Edge / Prerunner Suspensions 13 08-30-2010 06:49 AM
cam sync. scaring me funkingonutz 3.0 Liter Forum 6 09-18-2008 12:34 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
