Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Reply
Thread Tools Display Modes
Old 02-05-2018, 01:28 PM   #1
JOSEPH169
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: daily driving and off road
JOSEPH169 is on a distinguished road
Default Dana 35 swap into Bronco II
Doing a Dana 35 TTb swap into the Bronco II. I have the Axle beams all installed and the differential has 5.13 gears and a lunchbox locker similar to an Aussie locker or lockrite (believe it's a lockrite. Putting the passenger side axle into shaft into the pumpkin and the internal spring will no compress fully. Took the spring out and the axle barely goes all the way into the suspension arm for the spindle. The TTB arms are from a Explorer and the diff pumkin i believe is from a ranger. Was wondering if the explorer and ranger TTb axles are the same length. Any thoughts or advice much appreciated. I do have a lift on the Bronco II and my coworker and I are afraid that the axle might push to hard inside the pumpkin and may damage the carrier or something else.
__________________
89 Bronco II:Superlift Brackets reinforced,6" BDS coils, Belltech 6400 shackles, Skyjacker 4" leaf springs, RLC front winch bumper,Smitty built waterproof winch, Dana 35, 5.13 gears
JOSEPH169 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 02-05-2018, 04:44 PM   #2
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
Any way to get pics?
DS shaft go in ok?
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0HO, M5R2, Twin-Stick NP205, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is online now   Reply With Quote
Old 02-05-2018, 04:55 PM   #3
JOSEPH169
Vehicle Year: 1989
Vehicle Make: Ford
Default
axle shaft goes in the diff fine, but the slip yoke part of the axle when installing is all the way in and the spring is not installed. once the spring was put in it would not go all the way in and could not get the spindle on. I'll try to post some pics soon.
__________________
Old 02-05-2018, 05:28 PM   #4
85_Ranger4x4
December 2013 OTOTM
Vehicle Year: 1985
Vehicle Make: Ford
Default
Spring being the C clip eliminator spring?
__________________
Old 02-05-2018, 07:10 PM   #5
JOSEPH169
Vehicle Year: 1989
Vehicle Make: Ford
Default
That is correct. I was using the Yukon internal one and with it installed the axle would not push in far enough to allow the spindle to go in and even with no spring it still is pushed far out and we're afraid it might push into the carrier or the locrite locker too hard
__________________
Old 02-05-2018, 08:11 PM   #6
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
There is not enough space in the yoke to use an internal spring, you have to use an external one.
See here:
http://therangerstation.com/tech_lib...external.shtml
(do not weld on your shaft like was shown there, hose clamps around the boot works fine)
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 02-05-2018, 08:24 PM   #7
Mountain12
Vehicle Year: 1998
Vehicle Make: Ford
Mountain12 is on a distinguished road
Default Help
I am new to the forum. How do I post?
Thanks
Mountain12 is offline   Reply With Quote
Old 02-05-2018, 08:38 PM   #8
85_Ranger4x4
December 2013 OTOTM
Vehicle Year: 1985
Vehicle Make: Ford
Default
You have to host them somewhere like Flikr and remote link them to here.
__________________
Old 02-09-2018, 12:04 PM   #9
JOSEPH169
Vehicle Year: 1989
Vehicle Make: Ford
Default
I'll do the external spring and see how that works.
__________________
Old 02-20-2018, 07:23 PM   #10
lvwill
lvwill's Avatar
Vehicle Year: 1992
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: stress control
lvwill is on a distinguished road
Default
The kit should have came with 2 springs. The smaller of the 2 is the one you want to use.
lvwill is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
dana 35 off centered after swap into bronco 2? surratt Ranger Axles 3 01-30-2015 01:31 PM
Dana 28 to Dana 35 swap on 83 ranger 4x4crzyman21 Ranger Axles 1 05-19-2014 01:10 AM
Bronco II Dana 44/ Ford 9" Swap kiethtyrrell Off-Road 4x4 Suspensions 22 10-16-2011 04:25 PM
bronco ii jeep dana 30 axle swap brando-commando Ford Bronco II's 39 02-05-2011 01:57 PM
Dana 35 to Dana 44 swap on an Explorer 94EXPLODER Non-Ranger Axles 2 05-30-2008 08:09 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
