Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions > All Other Ford Trucks & SUV's (No Explorers or Bronco II's)
Notices
Reply
Thread Tools Display Modes
Old 08-19-2018, 10:35 AM   #1
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: High Performance Commute
chewy012 has a spectacular aura aboutchewy012 has a spectacular aura about
Default Slave cylinder went out. Fuuunnn
Lost the slave cylinder yesterday just as I got to my destination, 80 miles from home. Slave cylinder gushes from the wheep hole at every pedal pump. I was able to get outta downtown denver with only 1 clutch application and back into my town with another 2.
Boy howdy, how I can't wait to do this job.
Of all the ways to breakdown, this was about as good as it gets haha. Also, my buddy towed my f150 about 6 blocks with is 1.6L fiesta. That was a good picture haha
Sent from my VS988 using Tapatalk
__________________
4.0L OHV, M5OD, 3.08 Rear, 205/75R14, K&N, Stock.
chewy012 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 08-19-2018, 01:05 PM   #2
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
Bummer
External clutch slaves didn't last as long but were easier to change
RonD is online now   Reply With Quote
Old 08-19-2018, 01:52 PM   #3
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Default
Yeah, i'd take an external slave any day
__________________
Old 08-19-2018, 06:23 PM   #4
rusty ol ranger
rusty ol ranger's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Tetanus Awareness
My credo: A legend to the old man, a hero to the child...
rusty ol ranger has a spectacular aura aboutrusty ol ranger has a spectacular aura about
Default
I prefer a good ol mechanical linkage.
__________________
I'm still doin' everything I used to do, it just takes a lil' longer now...
97 F250 460/E4OD------77 F250 400/C6
87 Ranger XLT "Rusty 2.0" 2.9/TK5
Member since March 2002
rusty ol ranger is offline   Reply With Quote
Old 08-28-2018, 09:37 AM   #5
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Default
If anyone is still listening, I just replaced the clutch and slave/tb, and its not feeling right. The pedal feels fully bled, in that, the pedal is firm with the hydraulic line disconnected, and prying between the tb and clutch fingers is tight. I've gone through bleed procedure about 6 times since the I plugged the line back in. The pedal feels a lot easier than it did with the last clutch, and it releases way at the end of the pedal. With my arm I feel the consistent spring back force all the way through the pedal, but it does feel like anything with my foot.
My book said 20-29 ft-lbs for the pressure plate, and I did 10 than 20 and stopped there as the bolts felt tight.
Do I need to tighten it down more?
I drove it to work this morning, it feels ok... Seems to shift gears well enough, but theres no feel to the pedal. And the end of the pedal grab I don't like. The clutch was the M-PACT 07097ST1 on rockauto, with which has almost a full face of material. The old one had only had about a 1 inch ring of material around the outside.
Also, I noticed with my foot on the brake, it starts to pull the idle down at about 3/4 and I can bring it to a stall, but again, it's like there's nothing there.
I've never had a clutch feel like this
__________________
Old 09-18-2018, 07:25 PM   #6
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Default
Haven't made any changes, about 500 miles in, no troubles. Huh.
__________________
Old 10-22-2018, 08:56 PM   #7
adam762
Vehicle Year: 1999
Vehicle Make: Ford
I use this vehicle for: Daily driver, wood hauler
adam762 is on a distinguished road
Default
i used a slave cylinder i got from Rock Auto in mine when I did it last spring. It certainly did feel different! Smooth and effortless. Took a bit to get used to the new 'feel' but I'm 6 months in and it's been peachy for a while. It just felt like it released differently.
adam762 is offline   Reply With Quote
Old 10-23-2018, 08:36 AM   #8
Denisefwd93
Denisefwd93's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT 4X4
I use this vehicle for: daily driver maybe off road someday
Denisefwd93 has a spectacular aura aboutDenisefwd93 has a spectacular aura aboutDenisefwd93 has a spectacular aura about
Default
When we changed out the bad M5OD, We used a rhino pack pre bled clutch slave and master from RockAuto. We did not replace the clutch and flywheel because there was plans to change the engine out but the engine runs so darn good and doesn't use very much oil so that may have been a mistake. This pedal feel is right at the top and only takes a slight pressure to disconnect but there is pressure all the way to the floor so my assumption is it's a very worn clutch disc, I don't like that it requires quite a bit muscle and I hope that will change with a new clutch someday
__________________
"old broad with a truck" 3rd Generation family HVAC business owner (retired)
http://www.therangerstation.com/foru...d.php?t=176465
Denisefwd93 is online now   Reply With Quote
Old 10-23-2018, 07:50 PM   #9
chewy012
chewy012's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Default
Yeah, mine seems to have settled in. Actually, it feels better than the old one the PO had in there. I like it. It definitely felt really light, but now that my leg is dialed in to it, it feels good.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1996 3.0L Slave Cylinder and Clutch Master Cylinder tharpka28 Transmissions 2 07-17-2018 08:54 PM
Slave cylinder mod kenwheeler Transmissions 3 05-03-2011 03:22 PM
Slave Cylinder glenn123 Transmissions 3 02-20-2011 10:28 AM
TK5 Slave Cylinder JoshT Transmissions 1 09-04-2010 06:44 PM
Slave cylinder saleenboy87146 Transmissions 4 08-06-2009 09:19 AM
1999-2018 / 959 Media LLC / All Rights Reserved
