krs
- Sep 28, 2011
- Reaction score
- 0
- Location
- St. Louis, MO area
- Make / Model
- Ford
- Engine Size
- 3 liter
- Automatic
All,
One more question on my engine swap saga....
I have the Taurus engine in and running. After running for some time, I see no leaks and no engine light (meaning no codes)!!!
BUT....
When I try to put it into gear - nothing happens!
What (I think) I know :
1. Transmission has fluid.
2. Wiring harness plugs are all plugged in.
3. Lever to shift gears was attached. I did take it off, jacked up the back end, and shifted it manually - nothing still happenned.
4. The 4 bolts are installed connecting the flywheel to the torque converter.
5. Tranmission lines are attached both at the transmission and at the radiator.
6. The drive-shaft is attached.
7. I did pull the transmission with the old engine (engine locked-up tight), but I did not dissable it in any way, and did not remove the torque converter.
8. When in park, the truck will not roll (tranmission is engaged).
9. When in anything other than park, the truck will roll.
10. When in reverse, the reverse lights do come on.
Help! What am I missing?
BUT....
