07 chevy uplander starting issues
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
2WD / 4WD
So I just got this uplander the other day and it seems ok so far. The last few times I started it it would take a few extra seconds to start the motor. when it finally would start there would be a big cloud of smoke out the exhaust. its an 07 chevy uplander with the 3.9 and 130,000 miles. previous owner didn't really know too much about it other than the brakes were done and he drives it everyday. Anyone know what this might be? I haven't had a chance to look under the hood and I'm at work for the next few hours. so the more info the better.
RonD
Official TRS AI
TRS Technical Advisor
8,297
canada
Check spark plugs
Cold start means "Choke" is set, so extra fuel is added, need a good spark then
Also there is an IAC(idle air control) Valve(same as Fords), it may be sticking closed
If you are pushing gas pedal down to get it to start then IAC Valve could be the problem
91stranger
512
Gets Mo Chicks
2WD / 4WD
So I pulled the throttle body off and cleaned it really good. it was black on the inside. should took a before and after pic but wasn't too worried about it plus I was on my lunch break and wanted to get it done quick.
rusty ol ranger
Im a Jeep guy now.
7,274
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
A legend to the old man, a hero to the child...
Check engine on?
Members online
Today's birthdays
Kirby N.
March Truck of The Month
