Front End Alignment
Spike3570
St John, In
Is it a basic front end alignment at a shop for a 2001 Ford Ranger Xlt 4x2? Adjust Toe, Caster/Camber?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Just toe and camber. Caster is not adjustable on stock suspension.
If it has the two piece driver's side upper arm a limited amount of caster adjustment is available.
pjtoledo
2,908
Toledo Ohio
Fords
3.0 2.3
if it has the cam adjusting bolts caster is adjustable on both sides.
turning the cams opposite ways does the caster.
True, but the factory bolts didn't have those, so technically not stock.
pjtoledo
2,908
Toledo Ohio
Fords
3.0 2.3
OK, now I'm going to mention "drivers side" in your previous post :icon_thumby:
pjtoledo
2,908
Toledo Ohio
Fords
3.0 2.3
ha ha, got it before 'ya fixed it! :D
pjtoledo
2,908
Toledo Ohio
Fords
3.0 2.3
well, if that doesn't blow my wings off :icon_confused:
Well the dang Brits drive on the wrong side of the road, so they have the driver on the wrong side too.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I had hard gas last week and now I can't find my parakeet.
Kirby N.
March Truck of The Month
