Common SAS questions
MEAKIN
Red Deer, Alberta
302
the motor doesnt bolt to it so i can take it out and rebuild without too much trouble. just thought if i didnt have to i wouldnt.
rangertoy
Firefighter
EMT / Paramedic
ASE Certified Tech
Bay Springs, MS
Solid Axle Swap 4x4
6?
MEAKIN
Red Deer, Alberta
302
anyone else think removing the crossmember and not replacing it is a bad idea? keep in mind 5.0l and 40"s. im concerned about the frame twisting under load. thanx
f4x4ranger98
Western Slope CO
I know you will need to remove it but you definatly need to replace it. I did on mine with a 2'' by 2'' 1/4'' walled piece in the front where the bumper use to be and also bent a piece of tubing that hugs the oil pan and bolts to the engine motor mounts are.
MEAKIN
Red Deer, Alberta
302
if anyone has pics of what they did please pm to me
