Gear Ratio
drifter22
I have a 2003 Ford Ranger with a 4.0, automatic, extended cab and 4 wheel dr. I get terrible gas mileage, 15 or16 mpg. The door jam tag says it has R7 differential, which 4:10, something you would need in a log truck! Has anyone ever changed the ring and pinion gears? I have been looking and I can not find any lower than 3:08. I would like to get it better, Rock Auto has a 2:73, but it's for a 7.5 ring gear and mine is a 8.8 inch.
Any Ideas, Gene
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
If you try to put 3.08 or smaller gears in that truck youll need a calendar to time how fast it takes to get to 60... 3.54 is as small as I would consider going. And unless your doing 100% highway driving your mileage will most likely drop even worse.
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,530
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
What size tires are you running? That's a major factor in gear calculations. Have you looked at this chart in the How To Tech section?
fastpakr
Forum Staff Member
TRS Event Staff
2,831
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
There's nothing wrong with 4.10 gears in an OHC truck.
Sent from my SM-G960U using Tapatalk
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I hate to break it to you, those things seem to top out at 17 MPG or so. You will probably get more bang for your buck out of a tune up than a re-gear.
scotts90ranger
RBV's on Boost
4,320
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
Yeah, auto 4.0L is going to be around 17 tops, all highway I got ALMOST 20mpg with my manual trans explorer...
I'm with them though on tire size as well, while you were looking at the door tag, what size tires did it say it came with? what's that compare to what's on it now? If you have bigger tires on it now than it came with you are going further per revolution than indicated moving your mileage up...
I'm running 5.13:1 gears, gearing goes with tire size and overall vehicle setup, the '91 explorer I mentioned above came with 3.55 gears, I swapped it to 3.73 gears and a limited slip axle and with 235 75 15 tires from the 225's or whatever that thing came with, was a perfect combo, I think it cruised at 2000rpm at 60? don't remember exactly it's been 6 years...
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
High teens are about it for a 4.0L. And yes, tire size will play a huge roll in determining gear ratio. 3.08's might be ok for something still rocking tires for 14" rims.
8.8's do go down to 2.72 (sometimes listed as 2.73), but there's not a lot of aftermarket in that ratio.
drifter22
How much do you think 3:08 gears would help? I had a 1995 Ranger XLT and it had 2:73 differentials and I got a lot better mileage with it and took NO time to get to 70 mph. I pulled a lot of heavy trailers with it and had no problems. Both had 265-70-16 tires. The 1995 was the same as this one except it was a 5 speed. If Ford could have made it so you could bleed the brake master cylinder, I would still have it!! I got a lot of 23 and 24 mpg and once in Colorado in the mountains, I got 27.8 with Texaco gas!
fastpakr
Forum Staff Member
TRS Event Staff
2,831
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
You added 2.73 gears to it?
kimcrwbr1
46
maplevalley WA
ford
2.8l
Your gas mileage is in direct relation to foot feed and the 4.0 is not a power plant. If you go with a 4.56 you will increase towing torque and it will be easier on the skinny pedal. You know you need to change both diffs to match?
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
273 gears front and rear with a ranger and 265 16 tires?....31 inch tires?
you swapped in old school dana axles....and
you had a 454 big block and turbo 400 transmission too?
with 31 inch tires that cammer will get its best all around economy with 4.10 gears. 308 gears and 31 inch tires will ruin it.
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
With 2.73 gears and 265/70r16 tires and a 5r55e trans you would be doing about 1,350 rpm at 65 mph. :icon_rofl:
drifter22
I have 265-70-16, I dose call for 245-70-16 on the door jam sticker. I looked it up and what I found was the 265's were 8 inches longer in circumference. I don't know how much that helps; don't seem like much. I have too many projects going now. Thanks, everyone for your help!
Gene
ericbphoto
TRS Event Staff
GMRS Radio License
16,530
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
Ok. Your original tires had a 29.5" diameter and the tires you are currently running have a 30.6" diameter.
4.10 gears shouldn't be too bad for those 265/70 r16's. You might get slightly better mileage with 3.73 gears. But the truck will seem a bit more sluggish on acceleration. I would leave it as it is.
This message composed solely of recycled electrons. Go green!
Staff online
Shran
April Truck of The Month
